Garden Logo
j
james davis Posted on Oct 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sir, I have a 8n tractor that I bought from my uncles estate. It has not been started in a10 yrs. I have changed the points condenser coil and plugs . it turns over and backfires through the exhust.
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Oct 12, 2018
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409022
Points
4988
Hi, Sounds like the valves need to be adjusted. You need to readjust and also check the timing. Hope that helps.
Roger Paull III
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Expert 318 Answers
 Roger Paull III
Expert
Level 2:
Dedicated:
Answers
318
Questions
0
Helped
118410
Points
785
Probably needs to be timed. It's kinda hard with points because they have to be gapped i think.
5 Related Answers
Anonymous
  • Posted on Apr 15, 2009
SOURCE: 8n tractor runs good at first then after awhile starts to sputte
Check fuel filter in the shut off bowl. Then check the needle and seat in the fuel sediment bowl on the bottom of the carb.Also check the float when you pull off the sediment bowl.
Anonymous
  • 69 Answers
  • Posted on May 19, 2009
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
Anonymous
  • 69 Answers
SOURCE: HAVE A JOHN DEERE 318 LAWN TRACTOR, CHANGED POINTS
Check the coil impedance on the primary and secondary side. You'll have to disconnect the battery negative cable so you don't short something out. Unplug the spark plug wires and the two sets of smaller wires connected to the primary side of the coil. The primary coil reading should be between 3.7 ohms and 4.6 ohms while the secondary (spark plug side) should be between 34.2 k-ohms and 41.6 k-ohms. If the resistance values you measure are outside of these ranges, you need to replace the coil.
Anonymous
  • Posted on Aug 29, 2009
SOURCE: no spark at spark plug center of Coil
2000 ford escort ZX2. 4cyl . No spark at the spark plug. Wires are good.
Anonymous
  • Posted on Dec 30, 2010
SOURCE: 8n (front mount distributor)seems to be frying
Had the same problem, but was my fault for bypassing the ballist resistor (my bad). Anyway, I fried the coil. Read all the posts and bought new 12 volt coil (it has been converted before I got it 13 years ago). New points, condenser, cap, rotor. Now it is just my timing is a little off, but I have strong sparky but not enough to fry my coil again.
If anything, keep the ballist resistor. it is needed to drop the voltage to the coil so it doesn't fry.
I have fire at coil but no fire through sparkplug wires
The problem sounds like it is your distributor. Replace the ignition points and condenser, make sure the points are gapped properly. If you still don't get fire at the plugs, change the distributor cap, rotor, and wires. Points and condenser kit runs $9.72.
http://www.yesterdaystractors.com/ATK7FA_Ignition-Kit-4-Cylinder_14717.htm?gclid=CJzJscSG47sCFXPNOgod31wAqA
1helpful
2answers
How do i get a blue spark
The issue is spark yes/no. The color is not really relevant. Any spark will usually fire the mixture.
8N tractor will not start with starter button but will start if rolled and dump the clutch.
ignition key faulty
no power circuit to the coil while in the start position
check wiring in that circuit
check for all safety micro switches are operational as they are all connected to that circuit
8n (front mount distributor)seems to be frying coils, one day working just fine, next doesn't spark at all, New condenser, plugs, wires, rotor,points, distributor cap. Replaced coil last time seemed to...
1helpful
Not getting spark all the time after putting new
Clean the points with an emery board if this doesn't fix it roll the motor until the points are open then short them with a screwdriver if it arcs see if the coil is putting out spark if not get a new coil
3helpful
2answers
No spark at spark plug center of Coil
2helpful
2answers
Have new plugs, wires, cap, coil, rotor points, condensor. Still no spark
Check for power getting to the center top connection at the coil.
Are the points opening?
Are they fully closing?
Check for a grounded connection/wire in the dist?
Be very careful how you set the coil onto the dist.
Ford 8N wont start
It sounds like the conversion was more trouble than it was worth. I won't claim to have the solution to your problem having never worked on an 8N, but I was wondering about the capacity of the points and condenser in the distributor. If the condenser is not 12 V also, it might be causing the points to melt which would keep from getting a spark at the plugs. Check the condenser for voltage rating and also check if you are getting a spark at the plugs by unscrewing a plug, reconnecting the high tension lead, and hold the edge of the plug against the block while cranking using thick leather gloves, insulated pliers, rubber, or other non-conductive material to keep from getting shocked.
Top Garden Experts
Jay Finke
Jay Finke
john h
