I translated for you. How can a laptop in HP not go on but have a power?"
Please use English, ok?
"How can a laptop in HP not go on but have a power?"
or more simply my PC is dead.
no PC stated, 32years and 1000s of models.
laptops have 2 power sources
AC power pack,
DC battery pack
it can run on both alone.
on AC the battery charges, and PC runs on AC.
with battery out PC runs on AC for ever.
if you have problems with this PC
post symptoms first. ok?
tell what PC It is of the 1000s of models
what OS it runs
and what are the symptoms
that is the good, the bad or the ugly.
no PC stated
no power ! (squawk)
causes:
1: no AC to the home. (black out)
2: no AC to the room (breakers fuses tripped)
3: AC power pack dead. to PC.
4: DC large battery is shorted in laptops remove it leave it out, run on AC alone.
5: Desktop PSU is dead.(bad)
6: the power button is broken, or wires to it fell of or snapped.
7: the Motherboard has things connected that are shorted.(overloading the PSU)
in each case a real shop does testing,
using a meter, and fault isolation tactics.
guessing would be expensive.
so either learn how, or get it fixed by those that do.???
that is not a complete list.! ok.
SOURCE: Nais ko po munang batiin ang inyong show na
Pwede mo sya idemanda lalo na't kung kayo ay kasal. Responsibilidad ng isang ama ang suportahan ang kanyang mga anak.
Ang pinaka magandang gawin mo ay pumunta ka sa pinaka munisipyo o City
Hall ng inyong bayan at hanapin mo ang PAO (Public Attorney's Office).
Ang PAO ay nagbibigay ng libreng serbisyo sa mga nangangailangan.
Maraming Salamat!
SOURCE: kumakadyot ang car ko par 1st 2nd 3rd gear.pero
It sounds like you need a general tune up.
The problem would be timing, your ignition should be set to the right timing to avoid that acceleration hiccups.
Check also the spark plug gap.
Hope that helps you out!
thanks for using Fixya!
Kabayan paki rate mo ko at nice comments!
Testimonial: "tnx sir for giving me idea.bout my car problem.professional ka ba? "
SOURCE: is it a lost passport?
Hi there.
Kung 1995 mo pa pinalakad ang passport mo at hanggang ngayon ay hindi mo pa rin nakukuha, sigurado akong expired ang passport mo. Kung balak mo mag renew, ideclare mo na lang sia na lost passport. Kelangan mo magsubmit ng affidavit of loss upang makakuha ka ng panibagong passport.
SOURCE: connection error with hang
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
