Televison & Video Logo
Claudia Stafford Posted on Oct 14, 2018
Need to turn off captions on ROKU tv it is displayed in the middle of screen
wavesfix
Level 1:
  • Contributor 4 Answers
  • Posted on Oct 15, 2018
wavesfix
Contributor
Level 1:
Answers
Questions
0
Helped
3807
Points
11
To turn off closed captions on a Roku player, pess the * button on the Roku remote. Under Closed Captions, set it to Off. Press the * button again to close that menu.
5 Related Answers
A
Anonymous
  • Posted on Aug 01, 2008
SOURCE: tv set
the eprom in the set is probably going nuts , try unpluging for a day and see what happens if it does not clear the problem then tou need anew digital main pc board
Anonymous
  • 333 Answers
  • Posted on Nov 26, 2008
SOURCE: close caption writin words display all the time on tv how do i
Go to menu aand look for tv settings. go to closed caption and continue to scroll untill you see off
Anonymous
  • 541 Answers
  • Posted on Nov 02, 2009
SOURCE: I have a JCC AV-32D305 television. I use Direct TV
Unfortunately JVC had closed caption buttons on the remote and that is the only way to change the CC settings. Go to www.remotes.com and check to see if they have a remote for your set. Thanks
Testimonial: "Accurate in his comments! Also provided website to procure needed remote."
gopakumarg43
  • 76851 Answers
  • Posted on Feb 19, 2012
SOURCE: how do i turn off the closed captioning setting on my 27
Hello
Without its orginal remote, you can't turn OFF its close caption window.
If you ahve its original remote control, inform me by Fixya comment. I'll assist you to turn off this option. Without orginal remote control, giving any advice to you to rectify this problem, will be waste of time.
jhnolson
  • 822 Answers
  • Posted on Sep 13, 2016
SOURCE: How do I turn off the caption on my Denon receiver....I already made sure that it wasn't the TV or the Roku.
It is most likely under settings in the cable or satellite box.
26281725-v4uvew3xjjdpgmn3ctj2lcyg-4-2.png Hope this helps?
2answers
Why can't I get roku tv to show closed caption
Probly wearing out. But unplug set awhile to givit rest n reboot
Turn off captions on ROKU TV
To turn off closed captions on a Roku player press the * button on the Roku remote. Under Closed Captions, set it to Off. Press the * button again to close that menu.
1helpful
I would like to get closed captioning when I watch streaming netflix
Hi Shane,
Captioning is a function of the Roku box itself. Here's a FAQ from Roku to help you get it working. Good luck!
Roku Closed Captioning Help
Roku has been working for months tv screen turned black today in middle of program now nothing. Roku is working because power indicator lights up but nothing on screen.
Check the video output cable (HDMI or composite/RCA, etc.) from the Roku to the TV, to make sure it's still connected. Verify that you're watching the input on the TV that the Roku is connected to. If that doesn't work, contact Roku support. I hope your unit didn't just die.
2helpful
There is a black box, right in the middle of my screen when watching abc programming--doesn't appear during the commercial breaks--
Hello
Closed caption function in your tv is now switched ON. Turn it OFF. You can do it by pressing the [CCD] button (Closed Caption Display) button on the remote control.OK.
6helpful
2answers
WE HAVE A BLACK BOX IN THE MIDDLE OF OUR TV AND CAN'T GET IT OFF WITH THE REMOTE
Black boxes in the middle of the screen are text boxes. Text is a part of the closed captioning feature either on your television or your cable/set top box. You would press the closed captioning button on the remote repeatedly until it displays cc off or something similar. Captioning might also be active on your cable box/set top box. There is normally a hidden menu on the cable box and that is where closed captioning is. You have to turn the cable box off. Yes I did say turn the cable box off. Then press the menu button on it and then the hidden menu will pop up. Then navigate to closed captioning and choose disable.
A black box keeps appearing in the middle of the screen and stays on until I either turn off the TV or turn on the settings screen and clear it
Somehow, the cable box or some other device changed the settings for the caption box on the TV. While no closed captions were appearing on the screen, the box was being displayed. The box stopped popping up when the captions setting was turned off.
6helpful
My TV has a black square in the middle of the picture. How do I fix that?
Your screen is showing a black picture because the closed caption function has been activated. When this closed caption mode is turned on the screen will display an 80% black picture.
To turn off the closed caption and regain a full screen please follow these steps;
1) Press the Menu button
2) Use the up and down arrows to navigate to Closed Caption
3) Use the right or left arrows to select it.
4) Use the right or left arrows to select OFF
5) Use the up or down arrows to select Finish
6) Use the right or left arrows to save the settings and exit.
You should have your full screen back now minus the annoying black box.
Thanks for using FixYa. A rating is appreciated if the solution has worked for you.
2helpful
We have a large screen TV and it displays a solid
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
3helpful
2answers
Black square on screen of 19 inch TV
Check your closed-caption settings and be sure they are turned off. If captioning is set for text mode you can have this trouble. The TV blanks out a part of the screen for the text it never gets to display. Once captioning is shut off (or set for normal caption mode if you want to use it) the black box will be gone.
Top Roku Televison & Video Experts
vince
Paul Carew
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
