Question about Lumix Cameras
Regarding Lumix ZS60, since last few weeks back it showed some mark on lens supposed to be water mark but from inside of lens. tried warming it up little to get rid of it but not successful.
Mark is on outer lens but from inside, its quite visible in images as it takes reflection from surrounding objects and makes weird mark in all photos.
Anonymous
SOURCE:
Anonymous
SOURCE: LCD screen shows weird colours
Canon will fix this for free, regardless of the warranty situation.
Posted on Mar 19, 2007
Anonymous
  • 13 Answers
SOURCE: LCD screen black with white specs in picture and movie mode
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
Posted on Nov 11, 2007
Anonymous
SOURCE: water spot inside the lens on my Lumix camera
DON'T EVEN TRY TO TAKE THE LENS OFF!!!
To take the lens off, the camera has to be dismantled, and unless you are an experienced technician, there is a 95% chance that the camera will have more problems than what it started with.
Have you taken any pictures with the water spot inside the lens? If it is visible in pictures, then you have several options:
1. Ignore it.
2. Leave it there and use an image editor to clone out the spot in the picture. (Recommended).
3. Take the camera to a repair shop, or mail it to Panasonic's service center. This is the expensive option, to remove the water spot, the price most likely will be well over $100.
4. Buy another camera. The FZ7 is rated to about 50,000 shots, so if you are approaching this number they it may well be worth it to just get another camera.
Unless the spot is seriously affecting your pictures, then leave it there. By having the camera opened there is a high chance that other problems will be introduced, such as: fingerprints,dust or hairs inside the lens or misaligned lens elements.
My FZ7's lens is full of dust, yet this is not usually visible in pictures, when it is, I can usually remove it on the computer.
I would recommend taking the camera to a service center as a last resort.
Posted on Jul 10, 2008
Anonymous
YEAH GO TO WWW.BUY202.COM HE HAS LCDS CHEAP
Posted on Sep 06, 2008
Anonymous
  • 18 Answers
SOURCE: Dark circular spot on Ricoh R6 screen and images
There is a spec of dirt that made it inside the camera and has landed itself on your image sensor.
If you take a picture and the image has a spot on it, it could be the screen. If you transfer it to your computer and the spot is in the same spot, its something on the image sensor. You would have to send it out for cleaning, and a new camera would be cheaper.
Posted on Mar 30, 2009
Blurred image
A webcam is first and foremost a camera that uses a lens to gather light reflected by an object. There are a number of reasons why the image captured by the webcam can be blurry, all of which can be remedied.
Supplies from a photography store or hobby shop, along with items that most people already have in their homes, are needed.
The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu.
Aim the webcam towards you so that you can see the blurry image presented in the program's video window.
Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp.
Blow off the lens at the front of the webcam with compressed air.
Moisten the end of a cotton swab in photo lens cleaning solution.
Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge.
Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image.
Launch the webcam video program that is on the hard drive.
Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window.
Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field.
Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
Aug 01, 2013 | GE EasyCam Webcam
Can youi show me how to fix my webcam so i can get clear view , because i do not know how?
Step 1:
A webcam is first and foremost a camera that uses a lens to gather light reflected by an object. There are a number of reasons why the image captured by the webcam can be blurry, all of which can be remedied. Supplies from a photography store or hobby shop, along with items that most people already have in their homes, are needed. The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
Feb 12, 2013 | Logitech Webcam
Camera out of focus
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam. Hope this helps.
Jan 25, 2013 | Computers & Internet
Display field burned out
Jan 21, 2013 | Computers & Internet
I got new Sigma 18-200 DC II lens, with Canon EOS 5D Mark II it has black lens frame is visible through viewfinder or on the photo. Does it mean this lens is not compatible with 5DmrkII?
The EOS 50d Mark II is what's known as a "full-frame" camera. Its image sensor is the same size as a frame of 35mm film. The Sigma DC lens is intended for cameras with smaller sensors. The lens is compatible in that it will work with the camera to take pictures, but the pictures are cropped due to the smaller imaging area of the lens.
In order to use the full image sensor area you need to use full-frame lenses. In the case of Sigma, this means lenses without the DC designation.
Aug 03, 2012 | Cameras
5D-Mark II screen flashes with reflecting objects
No. It's simply a menu setting to show you where potentially overexposed highlights in the final image will be. The function can be set to show shadows or highlights.
I don't currently have a manual to hand, but if you can't find how to turn it off in your own manual then report back and I'll have a thorough rummage for one.
May 25, 2010 | Canon EOS 5D Mark II Digital Camera with...
I have a Sony DSC T-90 12.1 megapixel. I often
The vertical line can be caused by a very bright object in the image like a lamp or a silver surface reflecting the flash.
The spots are caused by the flash being SO close to the lens. Any object that can reflect the flash reflects it right back at the camera. This is an image problem with most point and shoot digitals. Watch for reflective surfaces and stand at an angle to them. Turn on more lights in the room before using flash. Stand at a slight angle to the image or person you are photographing - don't shoot straight on. (I kneel down and shoot up - makes a good shot too.)
If you are shooting toward the sun, shield the lens from direct sunlight with your hand (Keep your hand out of the picture!)
Mar 31, 2010 | Sony Cybershot DSC-T77 Digital Camera
Can u please tell me the solution
Did you have a hood or shade on the lens when you took the picture? You're seeing flare, caused by light hitting the lens and reflecting/refracting inside the lens. The most common source of the light is the sun, of course. If you don't have a hood, or are already using it, use your hand, a hat, a sheet of cardboard, or something to keep the sun from hitting the front of the lens directly. This can be a bit of a juggling act, since you don't want the object visible in the photo.
Feb 27, 2010 | Nikon D60 Digital Camera
How can I clean the inside of the objective lens on my night owl optics night vision?
front lens unscrews to check front of tube but if it is a black mark on screen then it is an internal tube phospher fault and cant be removed this is the case when you have cleaned front of image tube and screen of image and see no visibl marks
wayne
Apr 22, 2008 | Night Owl Optics Explorer NOCX3G Monocular
Spots on image when using built-in Speedlight flash
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
51 people viewed this question
Top Lumix Cameras Experts
Mikehimself
Mikehimself
Level 1 Expert
Paul Green
Phil Whisenant
Phil Whisenant
Are you a Lumix Camera Expert? Answer questions, earn points and help others
