Many owners of washing machines face such problems. No reason to contact the service center. You will be able to repair the washing machine yourself! All the necessary information about repairing the washing machine with your own hands is on the page of the specialized site - http://washererrorcodes.com/asko-washer-troubleshooting/
Drain pump may be obstructed
SOURCE: asko 6221 washer won't drain, now won't fill either
u will hve to get ur control card repaired.the problems u shared with us arises due to faulty circuit control card.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem...
SOURCE: Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
SOURCE: asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Hello Greg, welcome to FixYa.
To address your post of the washer not spinning and your curiosity of a faulty pump...the pump may simply be obstructed preventing a proper drain, thus a compromised spin, they are directly related. These frontloaders will not spin until they drain sufficiently. (though a faulty drain pump is possible, it woud be the exception, not the rule).
There is typically a drain filter in the pump as you may or may not know, based on your description it may be clogged. You'll need to access it, clean it out via draining it through the pump "emergency drain hose" before you can in the end open the door (though usually once drained to a safe level it will open under normal procedures) however there should be a door lock release on Asko built machines...including the W600 series.
This is the procedure for machines of the past 10yrs. or so...(this is only an example, it may not be exact but essentially the same as yours)
Hopefully this will help. Let me know if anything is unclear or If I can assist you going forward. Thank you for choosing FixYa and good luck going forward.
Regards,
Macmarkus :)
