Question about Zanussi Dryers
I have a zanussi condenser dryer it wont turn on the fuse in the plug is fine please help
  • 825 Answers
Check door micro switch
cheers
Posted on Oct 20, 2018
6ya staff
SOURCE:
prem mathew
  • 1294 Answers
SOURCE: Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Apr 04, 2008
Anonymous
  • 83 Answers
SOURCE: Dryer trips the fuse box
I had this problem with our hoover tumble dryer, it might sound stupid but i changed the plug and it worked ever since, ours blew 5 fuses and tripped out the main fuse every time
hope this helps martin
Posted on Jan 24, 2009
Anonymous
  • 4 Answers
SOURCE: Zanussi TC484W tumble dryer making horrible noise
Its the Rollers
Posted on Jan 06, 2010
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Posted on Jul 04, 2010
merimassi
merimassi
SOURCE: Zanussi tumble dryer
i have taken the back & top off and the belt is still intact - there fore not broken - please suggest alternative
Posted on Dec 30, 2012
My Zanussi ZDC 37200W has no power
Go to the self help section of repairclinic.com Enter you model number for specific trouble shooting advice on your appliance.
May 14, 2015 | Zanussi Dryers
My zanussi ZWD12270G1 wont turn on
THE MOTHERBOARD MIGHT HAVE FUSED OUT , NORMALLY YOU HAVE TO TAKE THE TOP OFF AND LOOK FOR A FUSE NORMALLY A 4amp LOOKS LIKE A GLASS FUSE LET ME KNOW
Dec 29, 2013 | Zanussi ZWD1270 Front Load Washer / Dryer
FZDC47100w
we had the same problem and didnt use our's for about a year as a result! brought it to a guy in Cork Street, Dublin. what he did was clean out the pump area on the left hand side, near the back and at the bottom of the machine. having cleared out the fluff and dust he washed it out, flicked some sensor switch a few times (under a small plastic cover he had removed on the pump unit). when he put it back together it worked fine.
Apr 19, 2012 | Zanussi TC7102W Electric Dryer
I have a Bosch Classixx Condenser Dryer which wont turn on - have cleaned out the filter - checked the fuse on the plug - still wont turn on. The model is WTE84107GB
Check the door interlock, this could be sticky or broken.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch Axxis WTL 6003 Electric Dryer
Hi, i have got a zanussi tc480 condensing dryer that is several years old. the problem is that after the cycle is completed the clothes are still wet.can you diagnose the fault? if so,what part is...
if they are wet then it is not drying, if they are damp then it is drying but the vent tube is restricted. Here are common problems for not drying:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
here is a website about the heating element:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
between the two websites you should be able to repair the dryer, if I was guessing I would say thermal fuse, you can bypass the fuse and see if it heats, if it does then replace it as it is a safety feature and left bypassed will cause a fire. the common cause for thermal fuse failure is a restricted vent tube, clean the vent if it is/was the thermal fuse. Good Luck Tim
Feb 11, 2011 | Zanussi Dryers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
TEC 7127: heats up but drum wont turn.
If it is new then you need to contact service agent, if you start messing about with it, you will invalidate your warranty.
Dec 13, 2008 | Zanussi TC7114W Electric Dryer
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Condenser dryer
doubt if squeak is related to not drying. if you are getting heat (you say heating element is ok) take out condensor and hose it down till thoroughly free of lint. check appliance has adequate ventilation as well
Apr 09, 2007 | Zanussi TC180W Electric Portable Dryer
Dryers Logo
107 people viewed this question
Top Zanussi Dryers Experts
peter gittos
peter gittos
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
