SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
SOURCE: on my old Singer 834, the bobbin thread puts out
Are you sure the bobbin thread is in the case correct. it also as tension support.Or is the bobbin thread right . When you make your bobbins that also should have tension.
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
