SOURCE: how do you open the front of the dryer?
Unplug your dryer from the electrical first.
You would remove the electrical box from the top of the machine that holds the timer switch/start switch,etc. Be really careful that no wires come loose in the process.
Then remove the top of the machine, then the front will come off after you remove the screws holding it together.
Good Luck,
I hope this helps
SOURCE: My maytage dryer Model
when did this problem start as it sounds like someone has changed the wiring to make it run. the timer for the bottom dryer has been wired to the other ect . i would think you need a tech to streighten out the wiring and find the reason for the changes . . mm feed back pls ..
SOURCE: how to remove the front
In the seam between the lower and upper front panel place a putty knife in the corners about a inch from the ends and push in and release the clips that hold that lower panel to the upper panel.
GENE
SOURCE: How to remove top and front panel on Maytag Dryer model MDE9206AYW
To access these parts you first need to first lift the top up. This is done by pressing the clips inward. These are located on the left and right side in between the top and front on the dryer. When this is done the top will left up and backwards. Next, on the upper inside there are two screws, usually 5/16" bolts, that will need to removed to take the front off. Now you'll will access to the inside of the dryer. The belt will have to be removed to to take the drum out to test the rollers.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
