Sansui tv SLED 55 FHD try RCA universal and go to cable then search channels use 3 or 4 if remote works change from demo setting
SOURCE: Wii turns on, says press A, Press A,Nothing happens
if the 4 lights flash on the bottom of the wiimote you need to sync the controller to thhe wii
SOURCE: PIP ON SANSUI LCD TV
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
SOURCE: JUST BOUGHT TV WENT TO ADJUST COLOR WAS CHANGING Call 1-8O5-465-751O Number To Fix
Try calling the service center for technical help at these numbers
Check the status of a repair at any of the locations below.
California Factory Service Center
JVC Factory Service Center
5665 Corporate Avenue
Cypress, CA 90630
(800) 252-5722
Georgia Factory Service Center
1500 Lakes Parkway
Lawrenceville, GA 30043
(800) 252-5722
This was all the Jvc.com website had to offer for customer service on the website. Hope this helps you with your problem.
SOURCE: Unable to pair a Philips Universal remote with Sansui TV
Hi
1032, 1051, 1052, 1054, 1061, 1075, 1079, 1091, 1140, 1157, 1173, 1203, 1209, 1232, 1237, 1258, 1287, 1337, 1339, 1340, 1375.
Regards
Phillip
