Dell W3706mc 37" Lcd Hdtv Flat Panel Tv & Monitor Hdmi Yd382 0yd382 Cn-0yd382 Logo
C
Chris Jarnot Posted on Oct 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 37” dell tv with static & popping noise. Model no. W3706MC. The picture is perfect. Would this be problem with Main Circuit Board? You can reach Me at [email protected]. Thank You!
Jeffrey Groves
Level 3:
  • Master 573 Answers
  • Posted on Aug 26, 2019
Jeffrey Groves
Master
Level 3:
Answers
573
Questions
Helped
140401
Points
1832
The best bet is to take the TV to a qualified technician for troubleshooting the audio issue that you are experiencing.
3 Related Answers
Anonymous
  • Posted on Oct 22, 2009
SOURCE: Remote Control for Dell LCD TV (model W3706MC) only glows
stuck button
Azrael SRL
  • 11800 Answers
  • Posted on Oct 26, 2009
SOURCE: how do I fix bad static?
Yes,loud static usually comes from bad isolation of sound signal path so it's probably a frayed cable or a loose jack. Or if you're unlucky some parts inside have failed.
Anonymous
  • 14553 Answers
  • Posted on Mar 14, 2012
SOURCE: No picture on Philips Model # 50PF7321D/37
The LED normally blinks--indicates the digital/main board is powered up.
Look for other fuses----Boards for these are rather expensive, maybe too expensive.
Google the model number with the word boards or parts after it to research it.
No sound on hdmi ports - Dell W3706MC 37 in. LCD HDTV
Dell W3706MC 37 in..
what does the small TV HDMI connect to , I can not see or guess your connections at all.
a sound bar?, I am guessing , why not just say what you are attempting, in detail.
Why is my Dell W3706MC TV hard to turn on?
The problem that you describe is indicative of a failing or failed power supply in the TV.
A reputable technician would need to troubleshoot the issue with the appropriate test equipment.
Need class D audio amplifier module for Dell flat screen model W3706MC
That's being specific lol I have the same board what other info do you need?
I get nothing on the screen. The blue light on the underbottom of the panel indicates power is on. There is no audio or visual data. I tried connecting to wall cable and HD antenna but I get nothing. I...
i just fixed this same problem on same model - its the main board on the back of the tv - find the part number off of the main board (the board with all of the av input jacks) replace it and that will solve your problem.
thanks,
phatcav
No sound, picture perfect. w3706mc. works first 6 months
Hook an external Stereo Receiver (or surround sound system) up to the Audio Out jacks on the back of the TV... this should allow you to hear the sound again.
Hope this helps.
1helpful
How do I fix bad static? Dell W3706MC 37 in. HDTV LCD has been fine and suddenly the sound has loud static on all sources. Is this a sound circuit failure?
I hooked up a HDMI cable on my dell LCD TV W3706 I have picture but no sound.
you will need to check you AUDIO SETTINGS on the TV and set it for HDMI
1helpful
The TV turns on; there is no picture or sound
your mainboard needs replaced from within you engine component located in the rear part of the unit. its the boad with the most inputs. google the board id and see if u can find a replacement.
2helpful
Just out of warranty Dell TV W3706MC,two years old
Sounds like a bad video board. No easy way to fix a bad video board. It needs to be replaced. That is why the repair shops will not fix it; they do not stock video boards for all models. And it is a pain to track one down all of a sudden. Once a warranty is up, you are running on bonus time. Electrical components have a definite lifespan. It is possible to recover some money by selling it "as-is" online somewhere. You could get 200-400 for it broken, pretty easy I suppose.
No sound
I do have sound board in stock.
Please contact me at:
[email protected]
Top Dell Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Paul Bade
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
