Question about Samsung Cameras
How can I input letters instead of numbers in Samsung 3.2 mega pixels ?
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: samsung camera charger
You can purchase a charger for your camera here
Hope it helps ^^
Posted on Jan 09, 2009
Rob C
  • 547 Answers
SOURCE: As I input characters - letters, it prints out
Go to Preferences, then general, then Digitizer.
You need to recalibrate the digitizer.
It will ask you to tap in two opposite corners, then at a target in the center of the screen.
Should fix you right up
Posted on Aug 08, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: Power Shot A620 Canon 7.1 mega pixel 3 years
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Posted on Dec 30, 2009
SmokinJoe666
Vijay A G
  • 77 Answers
SOURCE: when trying to input bank
Is it coming up only on your bank website? Try entering the same on a Note pad or Word document. If the problem is there as well, try the step below.
The scroll lock on your keyboard might be enabled. You might find Scr Lock button near the Print Screen button. Disable it and try again.
~SmokinJoe~
Posted on Apr 19, 2011
Kris
  • 73 Answers
SOURCE: Key board of Samsung Notebook R470 is
Oh yes, I have had this happen before and it sucks.
This problem is usually just due to having Num lock on. Try pressing the num lock button on your keyboard and see if this makes a difference. In the smaller notebooks and netbooks they combine the numbers and letters onto the same keys using num lock to distinguish the mode.
I think on your model the num lock button will be towards the top right of the keyboard. You may also have to press the FN (function) button at the same time, but I am not sure.
Also there should be a small led that illuminates or goes dark to inform you when num lock/scroll lock/caps lock are enabled/disabled.
Posted on Aug 28, 2011
Change language from Spanish to English on Samsung 1.3 mega pixels t-mobile cell phone.
  1. From any Home screen, tap Apps.
  2. Tap Settings.
  3. Select the My device tab.
  4. Scroll down to 'Input and control,' then tap Language & input.
  5. Tap Language.
  6. Select the desired language.
Sep 15, 2014 | Cell Phones
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Root my samsung mega 600
Do you mean the network unlock?For this you need not root the phone.instead approach Simpleunlocking.com and specify the model, country, locked network of Samsung Mega 600.Based on the availability you can get the unlock code along with free instructions.
http://www.simpleunlocking.com/samsung/rs16wp8/
Feb 02, 2014 | Samsung Cell Phones
Setting my Samsung ST76 to 1MB photos
I do not complete understand what you want. My fuss is, you want every picture to be about 1 MB on your memory card. I do strongly advice against this, but you own the camera and so it be. You always can make pictures with a smaller resolution from high quality pictures, but never the other way around. You better shoot highest quality on your camera and later wham the pictures are on your computer down size the ones that are less important to 1 MB.
But you can choose 5 mega pixels with normal compression or 3 mega pixels with fine compression or 2 mega pixels with super fine compression. All these pictures will look fine in an e-mail, or on the net. Even a 6 by 4 inch picture will look fine. Memory cards will cost like 1 dollar pro Gbyte, so my advice is buy a few 8 or 16 Gb cards and shoot in high def.
Nov 25, 2013 | Samsung Cameras
How do I change the dpi of this camera?
The digital cameras capture images with number of pixels that that image sensor allows. They usually dont have DPI adjustment. However you can adjust capture resolution from 5 Mega Pixel to 1.1 Mega Pixel. Please refer to Page 24 and 25 on the following Owners Manual for this camera.
Feb 24, 2011 | Kodak EasyShare C315 Digital Camera
SAMSUNG, Gigimax S500, 5.1 MEGA PIXELS, SHUTS-OFF WHEN TURNED-ON
There appears to be no rhyme or reason to your query - I advise you to contact Samsung directly,
Sep 04, 2017 | Samsung Digimax S500 Digital Camera
I have a problem with my camera samsung l730 7.2 Mega pixel .when i turn it on it doesnt show up the screen
Does your camera have a viewfinder as well as a screen? If so you may have the viewfinder turned on with a litttle switch instead of the screen.
Aug 01, 2008 | Samsung Cameras
Resolution
At the top of the LCD it indicates the resolution:
A small square with numbers and letters on it: 3.1M , 2.8M (3:2), 2.0M, 1.3M and VGA.
Oct 31, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
What is the number of recorded pixels on the DiMAGE 7i?
The DiMAGE 7i has four different image size settings; Full 2560x1920, UXGA 1600x1200, XGA 1280x960 and VGA 640-480. The recorded pixel size in each mode is almost equivalent to an image captured with a 5 mega pixel, a 2 mega-pixel, 1.3 mega-pixel, 0.35 mega-pixel DSC respectively.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Cameras Logo
89 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
