SOURCE: Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
SOURCE: Won,t switch on,fully charged,where can i find the
the rest for your go 700 is on the bottom where the mount connects,,see picture below.
bill
SOURCE: what is pentax optio z10 reset button
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
SOURCE: How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
SOURCE: pentax optio e85 will not
1) If your battery is charged separately (removing out of the camera) then try to plug in the contact properly, move it there and back to see if the indicator light changes its color. Sometimes cheap batteries, or chargers lose contact - you should open, find any lose contact and fix. For fixing lithium batteries rubber gloves and eye-protecting glasses are compulsory.
2) If your battery is charged inside of the camera - try to open the camera with a screwdriver and check for any lose contact, move it there and back until some indicator shows that the battery is finally charging. If you can't fix it yourself - a specialized mechanic will help you. Don't be afraid to bring him a disassembled battery.
3) If you conclude that the battery is dead - buy a new one on ebay.com or elsewhere. Remember that original manufacturer's batteries are sometimes more reliable but much more expensive than non-original batteries.
P.S. If this helped you to solve the problem (or at least brought some clarification) - rate this solution with 4 thumbs up! But before you would give a negative rating - post a comment, so I could improve my solution to satisfy your needs. Thank you!
