Delete pic. off of computer but when turn on the pic. the ones i deleted are still there
SOURCE: Deleting Pics.
Click on the picture viewer button and then hit the zoom button right next to it. Hit the trash button on the front of the camera. A screen will appear allowing out to choose All In This Folder. Choose that to remove all pictures from the camera.
SOURCE: deleting pics from memory stick
Option Go to list of pictures and check any menus like(mark ,mark all.delete all ) if have option mark menu -just mark all pictures and select delete. opton
2 if you have mark all -just -mark all -and delete
3.if you have delete all -just -delete all -it will delete all of your pictures in memory card
IF NOT OK
IF YOU REALLY delete all pictures and all datas
4.if you wish to do Formate the memory stick
now your Memory stick has Empty.
SOURCE: Deleting pictures from my camera jazz JDC31 Digital camera
Hi sjadl2840,
I presume you've already saved those pictures you want to keep in
another location and you want to flush everything in the camera.
Typically, you have a button on the back with a little trash-can
picture next to it. Pressing that will put you into Review/Delete mode.
You will usually need to use the up/down/left/right arrow keys to
navigate to select the photos you want to delete. Selecting the "OK"
or "select" button will select that photo for deletion. You will
typically have to confirm deletion for each photo, or before deleting
all (if your camera provides that option in it's programming).
These instructions are somewhat generic; if they don't work for you,
respond with a comment, and we can zero-in on your specific situation.
Beyond that, if I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
SOURCE: i cant delete!
u no how u turn the camera on?? keep clicking that same button till it comes to the trash can and then press the capture button (the one on top from which u take pictures)
SOURCE: How to delete photos from the DCIM section of my camera.
DCIM is a folder inside the camera. You can right click on the folder while the camera or card is connected to computer and select delete.
the camera will create a new dcim folder when it takes more picture.
let me know if you need anything else or if you need further assistance with this issue.
thanks and good luck.
ekse
