SOURCE: front load GE wont spin or wash
I can't find your models breakdown but it sound like a bad motor. if it drains and fills you have a good pump. if you had just a bad motor control if mostly would agitate. If the motor hums then you are getting power to it.. if you have no hum you can check for power with a meter.. if no power you have a bad control.. if you have power you have a bad motor... let me know what yo find out.. krazytech
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
SOURCE: GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
SOURCE: washer fills and drains, but the drum does not run
Joe, Thanks for the prompt reply. OK, it sounds like one of two possible culprits, 1) the belt has broke or spun off. 2) the brushes in the motor are worn...although the initial symptom of this is typically manifest in "no spin" so I'd lean towards a broken or spun off belt. You'll need to remove the rear panel for a visual inspection to confirm or dismiss either possibilities. Let me know what you find out. If the belt is off check for possible reasons "why" ? It can be a loose drive pulley, ( the large one, not the motor pulley ) or simply an unbalanced load on the previous wash, just a heads up since you're looking around in there anyway. Of course the belt itself may be worn ( stretched ) or broke and thus at fault as well. Good luck, I'll watch your post. macmarkus :)
SOURCE: My GE Adora front load
Did you get any error codes on the control panel? this sounds funny but have you cleaned the trap out? You have to clean the trap of the washer every so often (it is not mentioned in the manual. You take off the front bottom panel and you will see a round trap door to the right turn it and pull out and you can clean the trap make sure you put a pan under because water will come out as well. When the trap is full the cycles won't run. Usually this happens when there is water in the machine but lets try this anyway. Before you try this, unplug the machine, let it sit several minutes and plug back in, see if this helps before removing the filter trap.
