On both sides of the TV and in the middle of the TV screen
SOURCE: purple line down tv
tv needs repair ..possible bad buffer board or logic board bad and or possibly a bad panel ..
SOURCE: theres a line threw my tv.
It has a problem in the vertical sweep circuit that puts a nonlinearity
in its output and you see the glitch in the normally gradual sweep as a
line. Since a hit upside the set seems to help, you should just
resolder the whole vertical circuit area (doesn't take long) and see if
that cures it. If not, start replacing the electrolytic
capacitors in that area.
Hope Ya Fix It!
SOURCE: samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
SOURCE: No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
