SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
SOURCE: the wireless mouse works but the laser 5000
press connect on the wireless device...let go and then within 5 seconds press the button on the bottom of the keyboard. Repeat the same steps for the mouse whther its working or not. The problem usually is that the keyboard and mouse are on the same "Wireless Channel" and only resyncing them puts them on a seperate channel, hope this helps.
Erick
SOURCE: Sakar 62350N wireless multimedia keyboard stopped working
k i had the exact same issue. read all these posts online and no one could help me. so i took matters into my own hands. after removing all the screws from the back of the keyboard (figuring i had nothing to lose) i came across a very simple setup. and if you follow the two power cords that run from the batteries you will see they are connected to a card. two thin pieces of plastic are supposed to overlap each other and using the pressur from the back of the keyboard being screwed to the front of the keyboard connect to the power card. weeeeellllll i figured it must not have enough pressure agains the plastic pieces and put a lil piece of a business card i ripped up on top of them to make the connection tighter. WHHHHHHHALAAAAA ! freakin works! bahahahaha
SOURCE: my buttons wont work on my blackberry curve i can
I didn't drop this phone near water but felt the moisture was the issue with hot summer temps. with the 8330 bb, none of the buttons (only trackball worked- no buttons) Leaving it in rice for a day didn't work at all.
On the last resort attempt, believe it or not, the oven trick did!
1. preheated for 200˚F
2. turned off oven
3. took battery out of BB
4. placed on plate
5. left bb for exactly 20mins in closed oven
6. once i took bb out I waited 5 mins and then placed battery and turned on.
7. worked like a charm
