SOURCE: How do I remove the face plates on a Pfaff
The plate is not screwed in, it is held tight by a couple of metal springs on each side. Just take a small regular screw driver and gently pry up the face plate. You may have the presser foot lowered by the switch on the right side of the bobbin/shuttle area slide it so the presser feet raise.
SOURCE: I need a new mother board for Pfaff creative 1475
If you want to learn how to repair sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
SOURCE: My Pfaff 1475 CD stated batterie pile battery when
turn the machine to "on". Tip the machine on its back and you will see a little door on the left-hand side. Open the door from left to right and inside are two AA batteries. Change the batteries (both batteries go in with the at the top). Close the door, upright the machine, turn it off and turn it on again. The display will be 0 0 2.5. It's now ready to go.
SOURCE: My Pfaff Creative 1475 won't run. The lights are
there are 2 things it could be
1.the foot pedal could have gone out
2.the motor,,here's how to tell about the motor,, smell the motor & see if it has a smell to it,,if the motor has a smell like old dirty socks or a burn smell then chances are the motor has gone out
the motor would have to be replaced at a repair shop,, the foot pedal you should be able to do your self
websites for parts are--sewingpartsonline.com & sewforless.com
SOURCE: I recently found a Pfaff 1475 CD Sewing Machine
Find a local Pfaff Dealer HERE and ask them about availability and price.
How we discovered the real reason nice guys don't get laid, and a simple "fix" that allows you to gain the upper hand with a girl... without changing your personality or pretending to be someone you're not. learn more... ??? www.topcash28.com
