SOURCE: Battery life expectancy
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus CR-V3 long-life lithium batteries (LB-01) will provide approximately 500 shots. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times.
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times. Olympus recommends the use of CR-3V litium battery packs or NiMH rechargeable batteries. Do not use alkaline batteries unless it is absolutely necessary.
The battery life of AA alkaline batteries varies according to the manufacturer and power rating. Alkaline batteries can provide up to 100 shots with typical usage. Olympus NiMH batteries (B-01 4PE) provide approximately 250 shots per charge and can be recharged 300 to 500 times. Olympus recommends the use of CR-3V batteries or NiMH batteries. Olympus sells an NiMH Battery set which includes a charger and set of 4-NiMH batteries. You can purchase this through Olympus dealers or through the Olympus Emporium (www.olympusamerica.com/store).
Olympus Ni-MH batteries will last approximately 60 to 80 images and can be recharged about 500 times. The Olympus CR-V3 long-life lithium batteries provide power up to 2 times that of Ni-MH batteries. The CR-V3 long-life lithium batteries are NOT rechargeable.
The D-535Z uses two AA batteries, and Olympus includes alkalines in the box. Unfortunately those won't last long and will end up in the trash. So I recommend buying a four pack of NiMH rechargeables (plus a charger), which gives you a set for the camera plus a spare. Unfortunately Olympus doesn't publish any battery life statistics for the D-535, so I can't give you any exact numbers. It depends a lot on how much you use the flash and LCD screen. Don't leave the screen on all the time, use it sparingly and you should find an increase in shot numbers. BMW
