An example of battery removal for one model watch, which may be similar to yours, if you want to do it yourself.
A jeweler in a local shopping mall could do this for you cheaply.
https://www.ifixit.com/Guide/Nixon+Watch+Battery+Replacement/44278
Nixon Watch Battery Replacement
Pull the battery out of the watch, the number is stamped on the battery negative side, go on eBay and find the battery.
center: SR616SW sides: SR416SW
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
SOURCE: battery change for Nixon Kink watch
You have to open your watch caseback. Undo the battery holding contact, get the battery out and memorise the writings on the battery. Buy exactly the same one and replace it in the backwards way you took it out.
SOURCE: New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
SOURCE: user manual for nixon delta pu watch
Here you go,
http://www.nixon.com/manuals/nixon_delta.pdf
