Question about LG Washing Machines
I have an LG WM1812CW. The washer starts, fills part way with water then stops no error code. Next time starts goes 6 mins starts washing stops no error code. Next time goes a few minutes stops etc.. random What’s causing this so I can fix it
    Dedicated:
    Visited the website for 20 consecutive days.
  • LG Master
  • 483 Answers
Hello James,
Here are 2 link to help you diagnose and possibly repair the washer Good luck, JP
https://www.manualslib.com/download/1147300/Lg-Wm1815cs.html https://www.manualslib.com/manual/1246649/Lg-Wm1812cw.html
Posted on Jun 22, 2019
Anonymous
SOURCE:
Anonymous
  • 16 Answers
SOURCE: washer doesn't work properly
insider tip, when you follwo the directions take has posted. remove the hose from the switch only. then turn the switch to the lowest setting then reconnect the hose. this will allow the unit to reset to proper levels. do not try to adjust the switch or the tub will overflow. if this hasnt resolved the issue. you may need to replace the switch which is what may be the original problem. simple access to the switch. there is a lock tab on side of the switch press it and unscrew the whole switch 1/2 turn(unplug wire harness) it will now pull out (remove thumbturn on outside first of course) then install and reverse the process for install, please mark how it will go back in cause you can reinstall it in the wrong position. also note you will have to unplug the wire harness gl k
Posted on Jun 07, 2007
Jimster
James Greene
  • 240 Answers
SOURCE: Kenmore 80 series washer model #11092587210
Almost sounds like a timer or timer motor problem.  Could also be a loose wiring harness around the timer.  When you said it when into spin, but the next day, did the timer move at all during the "break".  Usually, a lid switch will give off that "tell-tale" clicking sound when lifting the lid.  See if it makes this noise, but it really doesnt sound like a lid switch issue.  Really sounds like a dead spot, or spots, in the timer.  Let me know.  Jim
Posted on Oct 18, 2007
Anonymous
  • 4 Answers
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
Posted on Jul 16, 2008
Anonymous
SOURCE: my LG Tromm washing machine
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Posted on Oct 10, 2008
Anonymous
  • 750 Answers
SOURCE: F25 error code
Hello twelsh2
Welcome,
You said, you started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
This is what F25 is telling you.
Condition
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Check and Repair
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power for 5 minutes (Rests the system)
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations
If you can not find the fault , Please call service.
We have service sponsors available in your area here in our web site if you need one!
Let me know what you find!
Huuum
Please remember to leave a rating!
Posted on Oct 13, 2008
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
    The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
    Feb 20, 2015 | LG Washing Machines
    FE Code for model WM1812CW LG Washer
    Hot water inlet valve most likely needs replacing
    May 14, 2017 | LG Washing Machines
    I am working on an LG front load washer model number WM1812CW. It will go all the way through a cycle one time. The next time it will stop between the wash and rinse cycle with an error code of OE....
    Hi jerryleigers,
    The Drain pump is working intermittently. It is either overheating or a loose wire is present or it could even just be a faulty drain pump. I'd suggest removing it (Found attached to the lower sump hose), testing it by aplying direct power to the 2 pins (either way is fine, it works on an alternating current), run it for 5 to 10 min (turning it on and off every 30 seconds), if it is fine then it is a worst case scenario (PCB). If it is not running well, or it is not even starting - replace it, problem solved.
    Hope it helps :-)
    * If you found this answer helpfull, please rate with a 4 thumbs up and a testimonial please.
    Apr 18, 2011 | LG WM1814CW Front Load Washer
    Oe error code, cleaned filter, checked hose
    You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
    Wait for door to lock.
    Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
    Press the START button two more times--this will enable the tub to tumble.
    After 3 hours--turn "off" the washer.
    Turn the washer back "on".
    Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
    This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Jun 04, 2010 | LG WM2277H Front Load Washer
    LE code flashing on WM1812CW
    LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
    Aug 27, 2009 | LG WM-1832C Front Load Washer
    Drum will not spin
    I unplugged the machine for 1 hour and the computer reset, and it is working fine
    Jan 04, 2009 | Washing Machines
    I have a whirlpool front end load washer and have been getting an f20 error message. we checked the inline water (fine), also the screen inline to the washer (clean). When starting a cycle, we note...
    code indicates pressure switch not tripped after 6 min...slow fill,water siphoning out(drain too low or too tight in standpipe)possible pressure switch under top right side
    Sep 11, 2008 | Whirlpool Washing Machines
    Washing Machines Logo
    996 people viewed this question
    Top LG Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
