Dryers Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer want start
How to install power cord
Anonymous
Level 3:
  • Master 2,418 Answers
  • Posted on Aug 04, 2009
Anonymous
Master
Level 3:
Answers
2418
Questions
0
Helped
812554
Points
6999
A dryer power cord is easy. Make a copy of your plug with paper by sticking it thru so you can match that at H-depot or so. Remove the back and you will see the conections right there. match color for color.
Anonymous
Level 3:
  • Master 398 Answers
Anonymous
Master
Level 3:
Answers
398
Questions
Helped
170284
Points
1257
A dryer cord has 3 wires. the center one is ground, the other 2 are hot. you must get your 220 volts when you check the 2 outside wires. . check center and each outside wire will give you 110 volts to 120 volts.
you must be very carefull when working with electric wiring it can and will KILL YOU.
Anonymous
Level 3:
President:
  • Master 1,776 Answers
Anonymous
Master
Level 3:
President:
Answers
1776
Questions
0
Helped
646833
Points
6310
I am attaching the photos showing how the dryer cord for either a 3 or 4 prong outlet, since I don't know what type outlet you are using. Hope this helps and best wishes.
  • Anonymous Aug 04, 2009
    In the 3 wire configuration, you will notice that the ground strap is being used under the center wire. The four wire is eliminating the ground strap and the green wire is attached to the dryer frame for grounding purposes.
Would the power cord installation have anything to do with whether the dryer has heat?
it has no heat because the heater is not working and was the reason it was sold
it may be a faulty heater element or switch but the cord has nothing to do with it.
May 20, 2015 • Dryers
Replace dryer cord
There should be a cover where the cable goes into. Look at your old dryer - notice where the red, black, white and green cables go to - they should be marked. Compare those to your new dryer. With the power cord unplugged from the wall, remove the cord from the old dryer and install on the new one. The cord should have terminals already installed - you will need a socket to remove the nut holdng the terminals down.
If the power cord is really old and the insulation cracks when you bend the cord, replace the cord.
I have a whirlpool dryer model #LER5636EQ3 which the power cord was missing upon aquiring it, the wall socket in my laundry room is a 50amp, so I need to know if a 50amp power cord would be a proper...
The recommended power cord is a 30 amp 3- or 4- wire cable. A 50 A cord could cause a problem by allowing a surge to the dryer motor and damage the dryer or start a fire. There are 30A to 50A adapters (see RV and boat supply vendors). The installation instructions for the LER5636EQ3 are available here: https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%203397618.pdf . See page 5 of the PDF.
Note: the 50A outlet has a 50A circuit breaker protecting it. If you swap the outlet to a 30A outlet, you will also need to replace the breaker with a 30A one.
I hope this helps.
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
How do I install a 4 prong power cord from a 3 prong power cord
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 • Dryers
1helpful
How do I connect the a 4 prong power cord
Four prong dryer cord connections to dryer:
- Red to far-left or far-right screw on dryer (doesn't matter which side)
- Black to screw on opposite far-side on dryer
- White to center screw on dryer
- Green to dryer grounding screw
Any questions, please let me know.
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
2answers
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Top Dryers Experts
john h
