Http://mobile-cellphones.blogspot.com/
try to hard reset your mobile. but before that take backup of your samsung mobile. before hard reset first check sound setting of your samsung mobile if everything look fine then hard reset mobile. if even after hard resetting samsung mobile your sound problem not solved then check speaker connector on your pcb.
SOURCE: i need unlock code for samsung sgh-a777 cellphone
By watching this video you can do it.
Click on the link....
http://mobiles.sulekha.com/samsung_sgh-a777_video_reviews_1555.htm
SOURCE: how to replace samsung SGH A777
its a simple but delicate process. take the battery door off and the battery out and begin with the screws in the back of the phone always work back to front. after that with a flat screwdriver split the outer shell of the phone off this will allow you to view the board of the phone with all your data and information. Remember BE CAREFULL there should be one or two flex cables connected by little snap connectors. Undo those very carefully if any of those get damaged the phone may not function right after its back together again. Make sure everything is disconnected and pull the board up and off the the side. Often on Slider Phones there is another flex cable on the underside of the board that must be carefully romoved as well. now its time to simply take all the screws you see out they will all be varied in size most of the time so try to remember where each one came from and not just throw them all together in a cup. Now that all the screws are out try to find a spot in between the front shell of the phone and the back half. Wedge the screwdriver in and pry it apart again be carefull for connecting cables we dont want to damage one and make more work out of this. now that that is apart you can see the back of the lcd or the screen of the phone slowly and gently pry that out its usually very glued in but that does not mean you need to push harder just take it slow and easy dont want to crack the screen. Now you can see all the parts out and individually and can easily diagnose the problem its either the screen itself or one of those conector cables.
You can send me an email to help more
Jon at The Cell Phone Guy Sioux Falls SD
[email protected]
SOURCE: PUK code for samsung sgh-a777
You can get the PUK code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call.The service provider will then provide you the PUK codes.. Remember that the reason why the codes are provided only through customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides PUK codes. All are fake. Only your service provider can provide these codes.
Thank you !!
SOURCE: how to unlock samsung cell phone from at&t
hi, as far as my experience has thought me unlock codes are the best method to unlock your phone, i used codes from http://www.onlinegsmunlock.com/ and http://www.mobileunlockguide.com/ to unlock my phone and it worked well jus check if your phone is listed for unlocking
SOURCE: im trying to unlock my phone but i forgot my sos
put this code on the display screen it will remove all codes *2767*3855#
