CMOS lock for battery just feel apart
SOURCE: I CAN'T FIND MY BLUTOOTH
If your sure you have it -you will find the settings in-Control Panel-- go to START>CONTROL PANEL
SOURCE: Why wont my emachines e528 laptop not load up but
RAM,PSU and MOBO failure are common cuses of your problem.
SOURCE: emachines e528 touchpad not working
Hello try to renew the driver from here:
https://support.gateway.com/us/en/emac/product/default.aspx?modelId=3234
Please unzip the file before you install.
Try uninstall the old one first
Or the touchpad have a fault.
You can buy a wireless mouse if you have no luck with the driver.
Good luck
SOURCE: Emachines e528 with out charger I cannot use my
I assume that you are looking for an e528 adapter. There are many adapters available on Amazon and eBay (search for "e528 charger"). If instead you are saying that the machine works fine when the charger is plugged in, but not when you are running off of the battery, then how do you know that your battery is OK?
