Simpson eziset 550 washing machine
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Testimonial: "i will try it thanks "
SOURCE: My simpson eziset 550 washing machine just stopped
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Testimonial: "thanks for the tip"
SOURCE: Looking or a service manual
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer service manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct? You may find, however, that it will supply schematics only to service engineers but good luck anyway.
John C.
