I have atw4475xq washer, the cold water keeps running will not cut off
    Passionate:
    Visited the website for 10 consecutive days.
  • 164 Answers
Change the cold water valve
Posted on Nov 04, 2018
    Top Expert:
  • Washing Mach... Master
  • 6,289 Answers
Water level switch or water valve problem depending on what you have to do to get water to stop. If only way us cutting off faucet, then water valve is defective.
6ya staff
SOURCE:
Anonymous
SOURCE: cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Posted on Jan 25, 2009
mike cooksey
  • 163 Answers
SOURCE: washer overflows
water valve maybe bad.but take screws out of face of machine and lift the face to see if your vacuum hose is pinched or pulled off from water level switch.also check to see if vacuum hose is on tub of machine.
Posted on Mar 06, 2009
Anonymous
  • 55 Answers
SOURCE: cold water won't run into washer. warm is fine,
Hello.
If the cold water will not run into your washer you will need to replace the water valve on your unit.
Posted on Jul 16, 2009
Anonymous
  • 85 Answers
SOURCE: cold water run into washer slowly. Pull off cold
water may flow fine through the hose itself, but you prob. have a damaged water inlet valve on the washer.. ( what the hoses are conected too... hope this helps...
Posted on Oct 27, 2009
michael
  • 155 Answers
SOURCE: washer runs but the water does not turn off,
while machine is filling turn of power if the water is still entering machine you have a mechanical fault water valve hot or cold needs replacing if water stops when power turned of you ave an electrical or control problem check water level hose from tub to level switch for damage or perishing if ok check water level switch blow into it see if it clicks if not replace also while blowing hold pressure to see if the diaphragm in the pressure switch is not perished keep me informed
Posted on Nov 06, 2009
Testimonial: "Great information. I will helpbme locate the problem in a rather than just hunting. I will order the replacement parts and let you know"
During wash and rinse cycles, washer stops loud buzzing noise, turn it off , wait a few minutes and will restart after a few more minutes will do the same thing again ??????
does it allow much water into the tub? u may beed to check ur water inlet valve for OHMS and for proper voltage at the coils, they may have went bad
Jun 02, 2015 | Admiral ATW4475XQ
My washer is not ringing my clothes out properly
check ur clutch, belt, motor coupler, or a plugged water pump or drain hoses
Feb 23, 2015 | Admiral ATW4475XQ
Admiral ATW4475XQ leaking from bottom but still washing fine
This could be a small hole in the drum or drain hose or valve for the water controls.
May 20, 2014 | Admiral ATW4475XQ
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Atw4475xq admiral
It's likely some sediment was disturbed during the valve replacement and clogged a screen in the washer valve. Turn off the water and remove the cold hose from the back of the washer. Just inside the threads you'll find a fine screen that you'll want to remove and clean (flush with water). You might also find a screen in the hose washer on the supply valve end of the hose. Check for that too.
Feb 19, 2018 | Washing Machines
Water keeps running in i have got to cut water off to spin dry
There is an electrically controlled water valve for both hot and cold water on the back of the washer, do both settings not shut off? if it is just the cold pull the washer out and replace the cold water solenoid water valve.
Mar 10, 2011 | GE WSXH208A Front Load Washer
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Washer runs but the water does not turn off, THe waterm hot and cold just run until I cut it off manually.
Nov 05, 2009 | Washing Machines
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
