Check the onscreen menu, look for timer setting. ..cheers
Philips 55PFL5601 F7 manual Here's a link to your owners manual
SOURCE: turn off touch pad
When you are booting up from a cold shutdown, Tap the F2 key until you enter the Bios/System Setup Pages. Usually you use the Alt+P key combination to navigate in these pages, but there should also be a legend at the bottom of these pages to indicate what keys change pages. In these pages you will come upon your option to choose pointers. One is usually, glide pad + mouse. I'd try that first, as it senses when a mouse is attached and disables the glide pad. However, this doesn't always work with Dells. So, if that is the case, choose Mouse Only for a PS2 Mouse and or Serial for a USB Mouse.
The Glide Pad is found in the Control Panel, Mouse where you have a property tab that has the settings for your glide pad. Besides setting pressure sensitivity you can also disable it in some Dell Systems.
If none of this works for you, look on the bottom of your laptop for the Service Tag number and send that set of numbers and letters to me using the comment box below and I'll find you the driver update that should repair your Glide Pad.
As always, please rate all our solutions on FixYa.
Always here to help,
Worldvet
SOURCE: TV has no picture, shut off in the middle of a show.
Greetings!
There's a part inside of your tv that over heat, when a minute comes it stop because of the heat. Better check with a tv technician or repair man before the damage became worse.
Thanks.
SOURCE: Need user manual for magnavox tv model 26MF301B/F7
Hi Joyce,
Happy new year!
Download the User Guide by clicking on the link below.
www.magnavox.com/p/index_tv.php?id=73
Click on downloads at the top of the page and to your extreme right.
Hope this helps.Thanks!
Please rate this answer.
Testimonial: "Thank you for your help. You get a score of 100. Happy New year!"
