SOURCE: Toro leaf blower has spark but will not start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You
will need to disassemble the carburetor and spray
with carb.cleaner. Make sure the small screen is free of debris.
(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),
to clean the small portals in carb. These portals can
become blocked. Reassemble and start.
Just let me know if you need further assistance.
Jim
SOURCE: Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: when we started using toro
You must use at least a 12 guage extention cord . Your current cord mostlikely can not handle those amount of amps for long duration of time.
SOURCE: Looking for MTD / Toro
Hi and welcome to FixYa. I am Kelly. You will need both your model number and serial number but you can get a manual at the link below that you can print.
(Most model and serial number plates list the model number, then a dash / hyphen, and then the serial number.) There is no other source other than a Toro Distributor for Owner's manuals or parts manuals. You can look up on line replacement parts on numerous sites.
Manual: https://lookup3.toro.com/request/request.cfm
Thanks for choosing FixYa,
Kelly
SOURCE: motor on mod 51591 died, nedd replacement
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
