Manual apparently for sale. One negative review on the web site, so I cannot verify it for you that it is legitimate.
(I saw Ebay.com sales of that model typewriter which include instructions, so you might try contacting a seller or two to see if someone would provide you a copy of the manual, or even offer to pay for a copy.)
http://www.devicemanuals.com/support/brother-ax-350-pdf-manual-82931.html
SOURCE: Brother Electric typewriter ax-22
sounds like it needs a good clean. Your best bet would be to look out for a Brother service centre or at least an established typewriter repair centre. Most modern technicians will be able to get your Brother working again...Good luck!
SOURCE: Brother AX-550
Go online to the Brother website or check your Yellow pages for a Brother dealer or you might Google the Make and Model...
SOURCE: in need of a brother GX-6750 typewriter owners manuel please help
First press the Code key and Q simultaneously. That will reset the wheel position. If it clicks or otherwise fails to type properly, pull out the wheel and inspect it. One or more of the types may be bent. In that case, the wheel needs to be replaced. Good luck finding the part.
SOURCE: AX-90 NAKAJIMA TYPEWRITER USER MANUAL NEEDED
Contact Nikajima @ 1-800-809-7138 they are very helpful.
DickyO
SOURCE: i bought a --brother AX-400 electronic typewriter
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
