Question about Sansui Televison & Video
Hi my sansui 74cm CRT tv have a sound problem when I turn the volume up it make's a cracking sound I've checked my speakers is ok
Go into audio set up and change setting
Anonymous
SOURCE:
Anonymous
  • 135 Answers
SOURCE: Humming noice
I have seen similar problems (features?) with Syntax LCD TVs. One thing to try is to make sure that the backlight brightness is set to its highest setting. On my Syntax, when this is set to a darker setting, it produces annoying hum through the speakers. Mine also is smart about turning *off* the audio amplifier when set to zero (or mute), which sounds like the behavior you are describing.
Posted on Apr 17, 2007
Anonymous
SOURCE: Compaq FP 7317 Speaker / Sound Problem
Sounds like the sound card in your computer..
Posted on Aug 18, 2007
TampaNative
Frank Fernandez
  • 778 Answers
SOURCE: Sound Monitor Compaq FP 7317
You need the proper driver for your monitor, and you will find it here: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&product=324199&dlc=en&lang=en
If you require instruction on how to update the driver, let us know?
Good luck.
Posted on Mar 21, 2008
Anonymous
  • 1142 Answers
SOURCE: A525 speakers giving cracking sound /disturbance
contact dell support and get the same replaced
Posted on Mar 28, 2008
Anonymous
  • 28 Answers
SOURCE: Audio Out Fixed/Variable
Is your subwoofer amplified or passive?
You clearly understand that you need to use a variable line out to control the subwoofer volume via the TV. As the setup seems reasonable, I'm wondering if the subwoofer is getting a signal, but that it is at line-level and not internally amplified by the subwoofer speaker. Generally, if the subwoofer must be plugged into an AC socket in the wall, it has an internal amplifier and can be fed line-level audio. If it is "passive", it has no amplifier, and it must receive an amplified signal (over speaker wire) from an amplifier (or integrated receiver). TV's don't generally have connections to send out an amplified signal.
If the subwoofer is indeed amplified, then this is obviously not the problem, but it's the first thing to verify given the information provided.
Posted on May 12, 2008
I cant hear any sound from my Tv Sansui SV2916. I
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Oct 09, 2014 | Televison & Video
No sound problem to sansui 1500w hardrock tv
Check its sound settings. If all the setting are OK, and no Mute function is set to ON, check the speakers first. If they too are found OK, check and replace damaged component/s at it audio output section circuit.
Aug 03, 2013 | Televison & Video
Sansui sv 29276 no sound
Check its speaker first. If they are found OK, check the audio output circuit for any damaged component/s. Check and replace the audio output IC.
Jul 08, 2012 | Sansui DTV2760 27" TV
Hi, I have had my TV for a few years now and it's always worked perfectly. Just yesterday, I turned it on and there is a picture and no sound. Any advice??
Take your remote press menu and scroll down to audio, check the audio settings carefully, if you find speakers off turn it back on that will restore the sound, failing that! check to see if the mute is on if it is turn it off to get the sound back. If none of these work I suggest a tv technician to remedy the situation.
Jan 10, 2011 | Sansui DTV2760 27" TV
Their is no volume
Hello
There is no sound you means? If so what about the picture? If picture is ok and there is no sound either the speaker of your tv or audio output Ic inside your TVs circuit board is faulty.
To check it, place your ear very close to the speaker side of your tv and turn it on. if a "thumb" sound or a "hum" sound is heard from your TVs speaker, the output Ic is faulty. If there is no sound at all, speaker is faulty. If you have any home theater system; and your TV has audio out RCA sockets at the rear or front side of it, connect it to audio system, and swich on both and find if there is sound output or not. If yes you can assure your TVs sound filtering system is ok, and the fault is somewhere between speaker and audio output Ic. Ok.
Oct 19, 2010 | RCA F20640BC 20" TV
My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to...
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Oct 14, 2010 | Aiwa F2000 20" TV
Hi- my 74cm TV- when i connect the dvd player and switch to AV- there is no picture only sound. But the dvd player works perfect on my other TV- what could be the problem??
If your DVD with same AV cord working fine on another TV then its a problem of cold soldering of video pin that needs touch up soldering. And tv work fine again.
Thanks for using fixya.
Nov 06, 2009 | Sansui DTV2760 27" TV
TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips tv.email me for wat happend
Dec 03, 2007 | SansuiM1315 TV
TV PROBLEM
I don't know your set in particular:
Genericaly, there are some models of sets that have a pre-set level for the sound. Check in to the menus of the set if there is a setting for the audio level at turn on.
Some manufactures designed their sets so that the sound is at about 30% up when the set is first turned on. This is annoying. They did that because they had people turn on the set and call their tech support that their set had no sound. It turned out that the volume setting was at "0"!
Jerry G.
Nov 21, 2007 | Philips 28PW6506 28" TV
Sansui TVM1915 Sound just quit!
if theres a headphone jack plug in a set og headsets. if the sound is there then you know that your speaker is bad. if its not make sure the volume indicator goes up and listen closely to the speaker. Do you here static noises?? NO? ok then its a problem with the audio output IC built in to the set and this is probably something you cant repalce unless your experenced with soldering printed curcuit boards. If you here staic or a small his then the volume contrpl curcuit or the audio if is defective and this as well is not something you can diagnoise unless you know how to troubleshoot electronics. Good Luck
May 04, 2006 | SansuiM1315 TV
Televison & Video Logo
41 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
