I don't know for certain but I have a theory - I believe some programmes collect and use bits and pieces of the Windows operating system rather than being a standalone completely self-contained programme.
I think over time and a number of restarts Windows manages to claw back some of those bits and pieces but not all. This effectively stops the programme working properly or altogether and when it is finally uninstalled the remaining bits and pieces of Windows disappear also so when it is reinstalled some essentials are absent...
Windows can function fairly well with lots of bits and pieces missing.
It is just a theory you understand, based on my experiences and observations.
bah on theory's , facts are.... as follows.
Encore is for music composition
yours is for XP and will not run on modern PCs.
no PC stated by you nor what OS. (making accurate answers possible)
all I can assume is it ran on XP but not on ,w7,w8 or 10
and cant.
but will not run on windows 10,
buy the never version if offered.
https://en.wikipedia.org/wiki/Encore_(so...
read that, learn the facts and then upgrade. for $$$
https://en.wikipedia.org/wiki/Master_Tra...
like this.
SOURCE: Had problems with my hp photosmart c5180 all in one.
You can download the latest Vista drivers and software for your HP Photosmart C5180 at this location:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&lang=en&dlc=en&product=1153481
SOURCE: need to reinstall print 6988
If you're on XP, download HP Deskjet Basic Feature Software/Driver and then install this software.
Next, go to the "Printers and Faxes" part of the XP control panel and add the printer. Unless the printer has its own server (very unlikely for home use), then even if it is installed on a wired or wireless network, you need to add it as a local printer (again this should be done even if you have it connected to your local network), then add the printer. You may need to add a new port for the networked printer.
I hope this helps.
Mike
SOURCE: Wireless stopped working on my HP Compaq Presario laptop v6000
Hi there!
There should be another adapter available. The two you mentioned are not your primary wireless connection.
The device will usually have 802.11g/a/b or something similar in it's name. It might also say Intel PRO/Wireless.
I assume you are uninstalling it because it is malfunctioning. The task you are performing can sometimes fix whatever the problem might be, but in the case that it doesn't, I would recommend downloading the most recent driver for the wireless adapter
Driver for XP - 32 bit
Driver for Vista - 32 bit
I hope this helps! Feel free to reply if you need anymore information or if you have questions.
Testimonial: "Having the info provided in the repsonse as to what devie I was looking for allowed me to find the write drivers and install them. "
SOURCE: once I installed magic jack my computer speakers
Windows XP:
1. Click Start
2. Click Control Panel
3. If your Control Panel is in Category View, double-click Sounds,
Speech and Audio Devices. If not, go directly to the step 4
4. Double Click on Sounds and Audio Devices
5. Click the Audio tab (the middle one)
6. Under both Sound Playback and Sound Recording, select your default
audio device (the one you want to use) from the drop down menu
* Never select Tigerjet as your default
device
7. Click the box labeled Use Only Default Device" (located in the bottom
left corner of the window)
8. Click Apply and OK
Windows VISTA
1. Click the Windows Button (Old Start Button)
2. Click Control Panel.
3. If your Control Panel is in Classic View, Double-Click Sound. If not,
go directly to the step 4.
4. Click on Hardware and Sound.
5. Click Sound.
6. Right-Click on your default device (the one you want to use) and
select Set as Default Device
device.
7. Click Ok.
www.sunwindproducts.com
