QUESTION: I just moved into a new apartment. The dishwasher is running normal but when it completes the wash cycle, my dishes are not clean and the detergent tablet is still there. The dishwasher is not dissolving the tablet. Maybe a little bit but about 80% of it is still there. I believe it gets hot water and runs normally. The apartment management said to use dishwasher cleaning tablets and not the powder soap. What can I do to try and get the tablet to dissolve? Any help you can provide would be great!
ANSWER: If your dishwasher hot water temperature is below 110F/115F, then it may not be hot enough to dissolve certain brands of detergent tablets. Be sure the water is HOT before you run the dishwasher. Run the hot water in the sink until it is very hot, then immediately run the dishwasher. Run the dishwasher on the longest, hottest cycle it has.
Also check that the spring opening action of the detergent dispenser door is working properly. If the detergent dispenser is too small a big detergent tablet may not be letting it open correctly. It may be jamming up the door. Try using a liquid or gel dish washing detergent if this is the case. There are many high quality liquid and gel dishwasher detergents on the market today. Liquid Cascade seems to be the best so give that a try. A powdered detergent will work too. Use a rinsing aid also as this will help remove spots even when the tablet may not be dissolving properly.
KEEP THE DISHWASHER DETERGENT DISPENSER CLEAN
If you are in an apartment, then most likely you do not have a high quality dishwasher. Knowing this, the dishwasher needs all the assistance it can get with the hottest water possible. You also need to be sure your dishwasher is clean at the bottom (removable strainer filter) where the pump and bottom washer arm is located. Be sure that it is clean and has hot water and this will be the best method to dissolve tablets. If you must use tablets, you can break them in half in the sink first. Place them in the dispenser and the hot water should make it easier to dissolve since the tablet is not as large.
You also need to be sure there is enough water for the pump to actually pump the water. To check this, start the dishwasher. Once you hear it running, open the dishwasher and be sure there is hot water and enough of it. If there is not much water in the dishwasher it may not be getting much water to the pump. When you open the door while it is running, check the water level at the bottom of the washer. If there is not much water at the bottom, then it may not be getting enough water to clean dishes and dissolve the tablet. Clean the filter at the bottom of the dishwasher to help the pump get the water more efficiently.
DISHWASHER PARTS IDENTIFICATION
If all else fails, you may have an old worn out dishwasher. The pump may be bad. Possibly your water heater is set to low. Your water heater should be set right around 120F. This will ensure that your dishwasher is getting the correct water temperature to effectively clean dishes and dissolve the tablet. If in an apartment, let the management know you are having this issue and they SHOULD resolve it.
Do you know of another way to assist a dishwasher to dissolve a detergent tablet? Please leave a comment below.
SOURCE: Kenmore Washing Machine
Open up behind, after taking off the wall power plug. Check to see it the hose from underneath the tub is loose, tighten. Or replace hose if damaged.
SOURCE: water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
replace the pcv valve. If it is not working it will allow pressure to build up in the crankcase. this will cause leaks everywhere.
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
