Why Does My Electric Water Heater Reset Button Keep Tripping?
So the red reset button on your electric water heater keeps popping out and needing to be reset.
Here's the most likely problem: The water in your water heater is getting too hot.
When the water temperature in your water heater exceeds 180°, the red reset button (also known as the high-limit switch) trips. This tripping protects you from getting scalded or burned when using hot water in your home.
OK, but then what's causing the water in your water heater to get so hot? The most likely cause is a bad thermostat.
How a bad thermostat causes your water heater reset button to trip
Electric water heaters have a lower and upper thermostat-one for each heating element.
The thermostats are responsible for controlling the heating elements. When the water has cooled off, the thermostats kick on the heating elements to heat the water. And once the water has reached your desired temperature, the thermostats shut off the heating element.
(This is very similar to the way your heating and air conditioning thermostat controls your home HVAC system.)
But these thermostats can go bad. When they do, they sometimes get stuck in the "on" position. This means that that the heating element continues to heat your water, eventually causing the high-limit switch to trip.
The fix: The bad thermostat needs to be replaced. A plumber can use a multimeter to test the thermostats and find out which one is bad.
Other problems that can cause your high-limit switch to trip
While a bad thermostat is the most common reason your water heater's reset button may trip, it's not the only one. Other common causes include:
Get a professional plumber's help
Do you live in the Minneapolis-St. Paul area and need a reliable plumber to help you troubleshoot your water heater problem? Contact MSP Plumbing. We can usually fix the problem the same day.
SOURCE: reliance water heater trouble shooting. I have to
I wrote a page with step-by-step troubleshooting for electric water heater.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
The quick answer for ECO reset problems is to replace thermostat(s) and then see of problem continues
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
