SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
SOURCE: Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
