SOURCE: GE front loading washer leaking
With only a limited amount of information, I would guess your door seal may be worn....but how can you check it? Take a reqular piece of paper (8.5x11) and cut a strip 1x11. Open the door and while holding onto the paper strip, put the strip in the TOP of the door and shut it to see how the seal 'feels' when you try to pull the paper out. It should be very hard, if not impossible to pull the strip of paper out. Now, do the same thing with the bottom of the door. Does it appear to be much easier? Without knowing the age of the machine, I might question the door seal. You might also want to check to see if the door might not be bent just a bit. Do this by placeing a long level vertically along the front facing with the door open, then check the door for level. It may be as simple as bending the top of the door out while you bend the lower part in.
Good Luck
SOURCE: moffat front loading washer user instructions/manual needed.
Head over tho the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: ge front loading washer door won't unlock
I had the same problem. I didn't want to spend the money or go to the trouble of replacing the whole latch assembly with the GE latch repair kit.
I found that the plastic latch piece screwed to the door had broken and one of the two latch "fingers" was stuck in one of the latch openings on the washer. I fixed the problem by removing the broken part from the washer and drilling and countersinking very small holes (1/16" I think) in the plastic latch piece on either side of the "latch finger". I then put the broken off piece back in place and drillled pilot holes for #4 sheet metal screws in the door where the latch is located. The door liner is plastic and I think I used a 1/32 inch drill bit. I reattached the broken latch piece with two 1/2 inch stainles steel #4 flat head phillips screws from Home Depot. The screws hold the broken latch piece in place as orinilally positioned.
The repair is working fine and the door now latches like it did before the latch part broke
Or: http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=2045520&pn_=WH10X10002
Same part cost $200 direct from GE
Read more: http://forum.appliancepartspros.com/washer-repair/8379-ge-washer-front-loader-door-wont-stay-latched.html#ixzz1LmNUKfTN
SOURCE: MY GE front load washer stops at 45 min 35 min
I had the same problem. Mine ended up being a cut in the pressure switch hose. Here's what I would do to troubleshoot:
1) Clean the filter down bottom one more time. Run a basket-clean cycle and make sure that the drain pump is working. If so, then move to step 2.
2) Do a diagnostic test. Here's some graphical instructions on how to do it:
Grab the codes off the t02 error codes test. There is a reference manual for the codes in a plastic envelope behind the bottom access panel on the front of the washer (panel below the door) -- remove the 3 screws then pull out from bottom. Lookup the codes and see what they mean.
Mine was E22 -- which indicates problem with pressure switch.
3) Do the t06 basket test. If it fails, then open up the top of the washer to check the pressure switch and hose:
Twist the pressure switch 90 degrees clockwise toward the spring to release it. Undo the hose clamps and blow down the hose. Blow into the pressure switch to make sure a contact isn't stuck. I took the bottom panel off the washer and disconnected the other end of the pressure tube from the bottom of the tub. Once disassembled, I blocked the end with my finger to see if the hose was punctured -- sure enough it was. I taped it and reassembled. If after repairing and blowing out, if you still have problems, replace the pressure switch ($60 on Amazon).
SOURCE: my front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
