Question about Yamaha Music
HOW DO I FIX THE YAMAHA PF80 FROM SKIPING NOTES. ONE PLAY THE NEXT NOTE DOES NOT PLAY
6ya staff
SOURCE:
petraman7
Scott Frye
  • 1175 Answers
SOURCE: Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Posted on Jan 12, 2009
Fred Yearian
  • 5603 Answers
SOURCE: Yamaha Electronic Piano- certain notes malfunctioning
Either the first or second closure matrix line for the "A" keys is bad.
This may be a cracked or shorted circuit board.
A bank of diodes is used to prevent sneak electrical path if more than one octave has notes pressed.
First thing is to clean ALL the key contact areas and the conductive rubber pills with 99% isoprophyl alcohol.
This involves dis-assembly of the key area. If you are not competent in electronics, best left to a pro shop.
The keys are scanned in a matrix, two contacts per key and all the individual notes are in common (all the "A;s", "B's"...) And each octave is strobed for the first set of contacts and then for the second set of contacts. an the whole octave is read in parallel.
The reason for two contacts is one closes first and then the other as a key is lowered. The time between these is measured and is the note VELOCITY which for a piano controls the loadness of the note. IF ONE of the two fail, the loudness will vary as yours does.
Posted on Nov 27, 2009
Anonymous
SOURCE: sustain is in reverse yamaha p-85
Make sure the pedal is plugged in before you turn the keyboard on and do not compress the pedal until the keyboard is on. Good luck.
Posted on Feb 08, 2010
Fred Yearian
  • 5603 Answers
SOURCE: My Yamaha PRS-293 will not play any of the E keys
The key switches are scanned as a matrix. One of the matrix wires has broken or connector/cable is not making it... It will be a connection in common with the non-working keys.
Here is schematic:
http://elektrotanya.com/yamaha_psr-293_sm.pdf/download.html
On page 40 on the board labelled 61H-MK and the connector DMLCD-CN401 the connections to pins 11 and 12 with signal names N14 and N24 have become broken or disconnected before they get to the processor board.
Since these lines are NEAR an edge, the cable could be not quite in the connector at one end or the other. These two wires are what triggers the E and the A# key signals. There are TWO contacts per key as one closes first then the other... this is how they measure key velocity.
Posted on Jan 17, 2011
Testimonial: "Thank you so much. You saved a good keyboard from going to a landfill! It was easy to fix with your information."
antonio barbosa
  • 137 Answers
SOURCE: Yamaha W 7 keyboard problem I have a Yamaha W 7
under the keyboard there is a switch for each key, try to clean it whit water and a smooth paper. I have Roland keyboards and it happens after playing a lot.
good notes
Posted on Feb 07, 2011
Testimonial: "Thanks for the info. I will give this a try and hope that this solves the problem."
I have ve a DGX 640. When the play the C, followed by D, the D is silent. It occurs also when I play the black key after its white neighbour.
Possibly a rubber contact switch problem.
Open up your keyboard if you feel confident about doing so.
Remove the rubber contact strip under the faulty notes and clear away any dust ( this can be a cause of the note not sounding ) Swap this rubber ( part 220 ) on attached picture with the one next door to it. If the problem has moved to the next octave then it is a worn rubber contact switch replace ( see link )
If not you will probably need to take to a repair centre as it may be more serious.
Apr 03, 2014 | Yamaha DGX640 Music Keyboard
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
YAMAHA PSR 9000 D NOTE VERY LOUD INTERMITANT
If you have any key note problems with your yamaha psr 9000 and need It repaired contact a qualified engineer at stephenhns5@gmail.com
Jan 28, 2013 | Yamaha Music
Playing certain 3 or 4 notes at a time causing sound of one or more extra notes.is there a quick fix?
Have a professional tune it for you. It may be that some strings have loosened/tightened.
Sep 06, 2012 | Yamaha P95 Digital Piano
As i play notes on my yamaha dgx 500 some keys remain showing on the little screen until a note or notes repeat continually.i can only remove this by turning it off ,sometimes the notes stop sounding...
Check if you MIGHT be in a "guide" or learning mode. Some Yamaha synths have a mode that will play and then wait for you to hit the right key before moving on. If this is not the problem, a fix is not DIY and will require repair. I assume you are NOT using MIDI as in that case it is called "dreaded MIDI drone" and is due to data looping back into the unit which is an external fault.
Aug 17, 2011 | Yamaha Music
I'm using the Yamaha P-85 Digital piano. Unfortunately it has lately had some problems. When I'm playing to notes next to each other (especially e and f (mi & fa) or b flat and b (si & si...
In playing fast you have to make sure to release the note fully and let the key come up. These keys have TWO contacts that are used in the scheme to measure note velocity. If BOTH contacts don't open, the note will NOT re-fire. The second symptom you have written would be a characteristic if one of the disconnect diodes has shorted. These diodes direct the strobe signals that scan the matrix of key contacts to avoid other octaves responding when multiple keys are depressed including those in other octaves. Servicing of the unit is required. It is unlikely you have the tools to DIY this problem. ONE THING to try is to tip the unit and gently tap it to see if some debris MIGHT have fallen in that may be shorting some of the matrix connections.
Apr 25, 2011 | Yamaha P85 88Key Portable Digital Piano
When I play my Bass Clarinet, the bottom joint won't play the higher octave. It will play everything except the 3rd octave B-E. I can't find any leaks.
usually If a certain note doesnot play the note before it is not seating correctly. Check all pads that they are sealing behind the bad notes, also make sure the octive key is sealing.
Feb 11, 2011 | Yamaha 5C Standard Bb Bass Clarinet...
Yamaha W 7 keyboard problem I have a Yamaha W 7 keyboard. Every now and then when I play the note A left of middle C the note keeps replaying or re-hammering while holding the key down. This started a...
good notes
Feb 07, 2011 | Yamaha Portable Keyboard
Yamaha 88 key piano grand plays wrong pitches w/ changing volume
If it has a sequencer/ recorder built in, you have the ability to change the pitch/ detune by using some key strokes after initiating the program mode. If your not sure how to do that, try unplugging the keyboard for thirty seconds and push the power button while it's unplugged, then plug it back in. Any better? What model is it.
Jan 01, 2018 | Yamaha Full-Size Keyboard
Music Logo
150 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
