SOURCE: security code becker indianapolis
Try code 42332
Testimonial: "Thank you very much from Holland!!! Eureka from Jo"
SOURCE: Becker Code please
I have same issue, so I called a local dealership. They said sure no problem as long as you have the vin# make model etc. of the original car. Or you have to bring it in to dealer to pull code from radio. Becker charges 20 bucks as well with less info. Good luck
SOURCE: How do i reset my becker juke box radio be2233
You must leave the radio turned on and most importantly the key must be in the ignition turned to the first point that turns acessories on.
You may have to wait for up to 2 hours before the radio returns to code and the power must not be interrupted during this time or the wait period will start all over again. Obviously make sure your car is in a safe place whilst you are waiting as key must be left turned in ignition.
When you get code back on the display you can enter your code as normal. If you do not have the correct code for your radio send your enquiry here and they will sort it out for you.
Thanks for using FixYa.
SOURCE: Becker BE4667 CDR32 radio code REQUIRED ASAP Model
3163
https://www.carstereocode.com/unlock.php?id=669
SOURCE: I need a security code for my Becker radio 4462 serial number BE446215085547
1360 from the four digits 4462
