Belt slipping or motor failing
Most likely a idler pulley wheel that’s badly worn
Based on my experience it maybe the rollers that support the rear of the drum and aod the drum to roll freely. You must open the dryer housing and expose the drum, remove the belt and pull drum out to expose the roller attached to the inside of the rear of the dryer. Replace rollers. Medium level of difficulty. Watch youtube on how is done by typing your model and brand name. Hope it helps.
SOURCE: heat element(spring) does not stay on long enough
you found the problem yourself, yes its a thermostat, replace this, however the heat should stop on longer than it does, but please note this is a part that should cut out & reset itself, if needed to prevent fire or overheating, this part has gone what we call tired, do not bypass anything on the appliance and use it, this can be dangerous and is against health and safety law etc before continuing to use the dryer check all pipes for blockages as restriction of air flow causes the problem you have, so to prevent another faulty thermostat clean out properly.....
SOURCE: We have a maytag neptune
i would replace the belt usually over time the belt streaches due to the weight of the clothes. the screaching ou are hearing is probably the belt going aound the drum instead of turning the drum.
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
SOURCE: MCG8000AWW takes too long to dry
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
