Started with pipes in wall making noise. Did main water valve shut off to release air several times to stop noise and shaking of pipes. Not sure if related, but now toilet in downstairs bath keeps filling in tank and overflows water into toilet bowl. Toilet in upstairs bath takes half an hour to re-fill after each flush. Have played with wall valve to adjust water flow into toilets, but does nothing. Am not savvy about toilets, but handy and curious if I can fix.
For the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
