Tools & Hardware - Others Logo
t
tim murphy Posted on Nov 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i remove the base plate of an ozito sander
Dave braun
Level 2:
Guru:
  • Expert 147 Answers
  • Posted on Jul 11, 2019
Dave braun
Expert
Level 2:
Guru:
Answers
147
Questions
Helped
122140
Points
327
Just buy a new sander being ozito not expensive
How to change switch Makita 9035 finishing Sander. How to take it apart to get to the switch. Thank you
Once you remove the 4 screws holding the pad on it will pry off with a screwdriver (use caution and work your way around - the bearing sits in a holder on the base and is just stuck)
Once you get that off, remover the pad feet and the housing should come apart
1helpful
Need a belt for a belt sander OZITO BSR-1000 75MM X 533MM MOST LIKELY GET 6 AS SO THIN MOB 0415337515 dave charles
belts are available from any good tool shop or large hardware shop
belt lengths and widths are stamped on the back of the belt
Information on replacing the four rubber bushings mounting to the base plate
Hi Kirk
Have you tried the Manufacturers site..
Doubt if any of our guys go that deep
Can you obtain a base plate with sandpaper clips
Probably not. Most sanders these days are designed to use Velcro-backed or adhesive-backed sandpaper.
Clarke plate sander vs drum for a floor that only needs
drum sander leaves chatter marks you must plate these out. belt sander is the best way to go, however it will take longer to just plate than to drum and plate. for light sanding i would start with a 60 grit on the drum, then 80, then 100. plate with 100 screen till chatter free, then final with 150 screen. this is if you intend to go to raw wood.
Threads gone in base plate
OK here is what I found at Hitachipowertools.com on your sander. If I am correct it should be a quarter sheet starting with the legs (if you need them) part number 322-756 qty 2, tapping screw 311-945 qty 2, base 322-759 qty 1 and screw 949--216 they show qty in pack of 10 so I would only order 1. Hope this helps and if you have trouble finding them let me know your location and I will try to find someone for you. Good luck
2helpful
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Top Sander Tools & Hardware - Others Experts
vince
Ngoro
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
