If you have the time and patience, take the back cover off the dryer if that is physically possible and sit listening to the pulley that keeps tension on the drum drive belt. It could be that the pulley bearing is going bad and does not make a noise until after it heats up under load. Or if you are mechanically inclined, after all the trouble of actually being able see the tension pulley, take the belt off the pulley and try spinning the pulley by hand (with everything unplugged). If the pulley doesn't spin or turn freely, it is a candidate for replacement.
SOURCE: My Maytag PAV2300AWW Performa is noisy on spin cycle
If you are talking about a loud sqeaking noise, this is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). However, if the snubber is worn too much, or if the brake assembly is worn they must be replaced. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
You can find all your parts and information at repairclinic.com. I am not affiliated with the website. I am merely recommending them because I have used their service before. Plus, they use the same repair parts as your major appliance repair companies, but at a lower cost.
The parts required to make the repairs aren't very expensive, but the tool required to do it IS. Also, if you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good abpout providing the necessary instructions with their parts, but this is a bit involved.
Post back with comments and let me know if this helps you.
SOURCE: Dryer overheats, stops mid-cycle
Usually it is a thermostat that needs replacing. When the vent is clogged with lint it will usually finish the cycle but the clothes are still wet.
SOURCE: Maytag Dryer clunking noise
may 26 2009
My maytag dryer is making a very loud squelling sounds in some of it cycles. still drying ok
gmalcom
SOURCE: Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
SOURCE: Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
