The Panasonic PNLC1040 is the charger for the KX-TGFA30 handset of the cordless phone system. One of the phone systems with this handset and charger is the KX-TGF340. You can set the Ringer Volume to off in the Menu of the handset (see page 30 of the manual). Make sure that the phone system is in Standby (no calls in or out or no other handsets are in use). Press Menu. Type in # 1 6 0. Alternatively, navigate to Settings with the Up/Down arrows, press Select (see the label on the LCD screen for the two soft keys above Talk and Off). Navigate to Ring Adjustments and select this. Select Ringer Volume. Use the Up/Down arrows to set the ringer volume to Off and then press the key for save. Press Exit to leave the menu system.
There is also a silent mode that turns off the ringer for all handsets and the base (or a select group of handsets). The basic silent mode is set by pressing Menu # 2 3 8. Select On or Off and Save. Set the start and end time of the silent time schedule. Press OK as needed. Use * to set AM/PM. Save and then press Exit to leave the menu system. This is described on pages 35-36 in the manual.
Silent mode does not prevent the phone from receiving calls and messages. If you want to disable Silent mode because you are in a location where it is OK for your phone to ring, edit the settings in Android. Use the power button. Press the Android phone's "Power" button and hold it until a menu appears on the screen.
What make and model is it? Does it beep when you press other buttons, or is it always silent now? It could be the speaker if there is no sound at all. Or perhaps you accidentally set the microwave to a silent setting. Try looking in the manual or searching online for silent mode for your microwave model.
@saioapicado I have same problem (need Windows drivers) but I'm not able to find Google drivers as you did, so - please - can you help me and maybe send those drivers to: [email protected] I would appreciate a lot. Thanks in advance. Michelangelo Togni
or by holding down the # key :) you may have changed the profile itself, so check under profiles > Silent check the settings in there are actually set to silent...
