Question about Casio CTK710 - Pianos & Keyboards
I have a CASIO piano LK-210.When i go to functions,when it comes trans. its written ---.I have tried numerous keys and tried up and down keys but in vain.PLEASE HELP
6ya staff
SOURCE:
sandrew
andrew pester
  • 2961 Answers
SOURCE: Acer Aspire 3000 Series Numerical Keyboard/Function Key Problem
if using XP go to my computer, right click>properties>hardware tab>device manager>look down list for keyboard, click '+' sign and highlight your keyboard and right click and select uninstall. Restart the notebook and the keyboard will be installed automatically along with the drivers and should set it back to default.
Posted on May 21, 2007
Anonymous
  • 3 Answers
SOURCE: function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
Posted on Jan 14, 2008
Anonymous
SOURCE: Casio Dual Time Illuminator - stop it beeping on the hour
Follow this link for a manual http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2481&submit.x=34&submit.y=9
Posted on Mar 31, 2009
Anonymous
SOURCE: Casio AP-5 "Celviano" Digital Piano Owners Manual
go to web site user-mauals.com
search for ap-5
Posted on Apr 20, 2009
Anonymous
SOURCE: Casio Privia Px-120 88 key digital piano frozed.
Hiya,
I had the exact same problem and the piano is brand new! I considered the possibility of the above answer as I had plugged it in via a power cable (it was missing the 3 pin UK plug) and it was also plugged into a power strip. My dad also looked at it and couldn't see why this should cause it...but I tried the different combinations anyway...including with the proper 3 pin plug attached to the adaptor (when it arrived in the post), rather than a power cable. This was the result:
Power cable +power strip = piano froze
Power cable (straight into wall) = piano froze
Proper 3 pin plug supplied + power strip= piano froze
Proper 3 pin plug (straight into wall)= piano froze!!!!
So....in answer to your question...I'd say there's something wrong with the piano! If not, it should've worked for me on the correct combination. :I I will now be returning mine. I worry what the cause is though considering my piano is brand new....and therefore is this a fault that regularly occurs with Casio privias? I don't want to spend this much money on one if it's going to do this eventually.
Posted on Jun 23, 2009
How do you replace a key on a casio 100 keyboard. which screws do you remove in the back
What kind/type of your Casio 100?
Casio MT-100,LK-100,CA-100,PT-100,CDP-100 ?
May 19, 2015 | Casio LK-100 Keyboard
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How to reset the Privia Px-110 back to factory setting
Try this
1. Turn off the digital piano
2. While holding down both the (TONE) and (FUNCTION) buttons, press the (POWER) button
Nov 17, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
When I plug in stereo headphones in the casio wk 210, the sound only comes out of one ear. I didn't really care about that before, but now when I connect a line out from the piano to my computer to...
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
Aug 04, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Some keys are not functioning properly and some of the keys have been breaking the chord rythms
This repair is probably beyond the DIY class of repairs. Best to take to a shop for repair.
Jun 08, 2011 | Casio LK 230 Lighted Personal Keyboard, 61...
HOW TO BUY CASIO KEYBOARD CTK5000 IN SRILANKA?
Hello
You can find this keyboard in some electronic shops in Colombo otherwise you can order on Amazon.com by clicking the link.
Good Luck
Feb 22, 2011 | Ovation Casio 61 Key Personal Lighted...
How to adjust the metronome on casio privia
You hold down the function key/button and then use the PIANO keys with the "tempo" shown above them.
In that section of the keyboard, the C# key raises the tempo and the C key lowers it. You can also use the numbered keys in that section to dial up a particular value. Hold function down and strike the numbers you want then release the function key/button
I don't believe there is an adjustment for loudness of the metronome other than the overall loudness of the piano..
Mar 26, 2010 | Casio Privia Keyboard Case
Midi
Anvil Studio is an easy way to prep midi files for keyboard use, save channels 3 & 4 "left & right" in Midi 0 format and it will light the keys properly. Keep your file size under 80k!
Oct 26, 2008 | Casio Lighted Keyboard LK90STADMC
Casio CTK710 - Pianos & Keyboards Logo
91 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ekse
Are you a Casio Music Expert? Answer questions, earn points and help others
