SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: What is m2 code how cani reset in Konica Minolta
This is to display the count of the supplies life counter.
When the counter is reached to 0 life 1 will be detected and maintenance call M2 will be appeared.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
- To clear the count, use [CLEAR DATA] of the Service Mode.
SOURCE: konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
