Question about Juki Sewing Machines
Juki 5550-6 bottom stitching has little loops every few inches What to do?
    Novelist:
    Scholar:
  • Juki Expert
  • 90 Answers
  • Frances, Check to make sure that you don't have a bad needle. If there is a slight burr on the point of the needle, it will cause this. Or if your needle isn't in straight.
  • If you have broken a needle, you may have a groove on the inside of the needle hole in your throat plate. You can take your plate off and buy emery string to run back and forth to smooth that out or you can buy a new plate. (look under your plate and there should be a number engraved on your plate to guide you into purchasing the right plate.
  • Check your bobbin to see if its wound evenly and that there aren't any grooves in the edges of your bobbin (if there is, throw it away).
  • Lean your machine back and run your finger along the outer edge of the shuttle to see if there is a rough edge that might be catching the thread as it revolves around. If there is, buy a piece of fine emery paper at a hardware store and buff it smooth
  • Are you using smooth thread and a big enough needle? If your needle eye is too small for the thread or the needle is too small to punch a big enough hole in the material for the thread to pass through easily, it will sometimes cause skips like this.
  • As a last thought, try a different foot. If your foot doesn't hold the material tight to the feed dogs while you are sewing, the material will 'follow' the needle up and down and cause skips.
  • Good Luck!
Posted on Dec 26, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: BOTTOM STITCH IS ALWAYS LOOSE
my top thread is pulling thru to the underside..looks like little birds feet tracks on the back of the quilt...help
Posted on Aug 09, 2008
Anonymous
  • 19 Answers
SOURCE: Where can i download a manual for my juki ddl-5550-6 for free?
sewingmanuals.com
Have you tried sending information to a Juki dealer? It's unfortunate/fortunate you can find some manuals online and have to pay but...
Posted on Jan 14, 2009
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
Anonymous
  • 111 Answers
SOURCE: I bought a second hand Juki industrial machine ,
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
Posted on Jul 08, 2009
sewtech915
SOURCE: juki 5550 - SC 800 with electronic display - it
E13 is appearing on the panel of sc 800 control box
no such error is listed on the instruction manual please advise
Posted on Jun 07, 2010
Error code E3 45786 on Juki sewing machine motor
I could not find that error using the Manual that is on the Internet.
I suggest you call or email their Sales and Service in the U.K.
Their email is sew-europe@btconnect.com
JUKI DDL 5530 DDL 5550 Parts Needles Service
Feb 16, 2015 | Juki DDL-5550 Industrial Straight Stitch...
I have a brand new Juki MO-50e and the threads are loose on the back of the fabric, how do I fix this?
  1. . re-thread your machine with a rainbow of colors. (important that you remove the existing threads if you are not sure it is threaded properly.) make sure you are lifting the presser foot while rethreading.
  2. Sew a good 6 inches.
  3. Look to see which threads are the offenders and tighten the co-responding tension knobs a little.
  4. Sew another 6 inches. Examine the result. Adjust tension again if needed.
  5. Work this way until you have the stitch balanced.
  6. Finally when your stitches are perfect. clip the threads at the spools in back. And tie on the coordinating colored thread for your fabric.
Get used to this procedure since it is common to have to adjust tensions when you change fabric. Good luck!
Oct 23, 2014 | Juki MO-644D Mechanical Sewing Machine
How do I know that machine is in working condition ddl-5550
A little more information please. I have this model, and it only does a straight stitch and reverse.
Have you turned it on and tried sewing on it? Is the oil pan dry? Has it been serviced at all, or maintained?
We can't help you without more info.
Oct 15, 2014 | Great Plains Ind. Juki DDL-5550 Industrial...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Bottom thread on Juki DDL-5550 is coming up. Top thread seems to lie flat
Check your upper thread at the spool. I've had industrial machines randomly throw a loop around the spool holder spindle which is hidden under the spool itself.
Also check your threading guide to be absolutely certain you are threading it correctly. Also make sure needle/thread diameter are suitable for each other.
Good luck.
Dec 02, 2012 | Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Hi there, i am oshi and i got a industrial JUKI machine.its DD-5550-6. It's a computerized machine. when I sew , it's missing some stitching along the way .Also i have a problem with under...
Make sure that the needle is inserted all the way up and is facing the correct way. Tighten the upper tension gradually until the stitches look even on top and bottom.
Aug 03, 2011 | Juki Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
