Go into source or input select internet source or blue tooth
SOURCE: SGH-E250 internet access via data cable or blue tooth to PC
can you please help me i dont knw to use USB
SOURCE: Vizio PIP second input source
Can you use a splitter somehow to make the cable be two inputs? That is all I can think of.
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF]
AVR-3300/1
3.3E*
SOURCE: Problem with Vizio SV421XVT
I am also having the same symptoms for my SV421XVT. TV works great except all HDMI ports are not receiving signal. Devices work through the AV Ports, and TV reception is fine. New Roku box is also not working through HDMI but works with AV. Wish I had a solution to this.
On a another forum for another TV it was suggested that boards need to be replaced. I hope I can get these boards for a reasonable cost.
The Picture in Picture
(PIP) on VIZIO televisions works on multiple input sources. This means
you have to have signal or a device connected to more than one input on
the television and have both inputs selected to display the information
going to them. Here is an example. Let's say you have an HD cable box
connected to your television and you would like to have more than one
channel displayed on the screen in order to keep an eye on both football
games at the same time. With one device connected that's not going to
work out the way our TV functions. What you want to do is get
a coaxial splitter and two extra coaxial cables; these can be found
anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4.
Connect your two extra coaxial cables to the OUTs on your coaxial
splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6.
Connect Cable 2 directly to the IN on your cable box, this will be the
same connection you removed it from in step #2. Your HD cable box should
still be connected to your television with either an HDMI cable or
Component cables (Identified by their Green, Red, Blue colors for video
and Red and White cables for audio.)
7.
Power on both the cable box and your television. Using the INPUT button
on your VIZIO remote select the input connection where your cable box is
located your cable box picture should come up on the Main screen.
8.
Press the PIP button on your VIZIO remote to bring up the small box in
the corner. Press the PIP input button until you select the TV input and
you should be ready to go. You may need to perform a channel scan with
your TV tuner to locate all available channels before you do this step.
In order to understand better how to perform a channel scan please check
under the F.A.Q.s in the discussion area of your particular model
television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
