To set the timer, you simply need have the camera in ready mode (as if you were going to take a picture normally), then on the back where you have the four directional pad buttons, with the camera facing you press the left button once and you should see a circle with the number 10 in it. If not, press again. This is the timer for 10 seconds. If your press the left button again, you will see a circle with a 2 in it. This is the 2-second timer.
Now choose which one you want, the 10 or 2-second timer. Once you have decided, press the shutter button fully and you will start to hear beeping. This is the count down sound. Now depending on if you have the flash setting to go off, once the beeping and the self-time indicator on the front of the camera stops flashing, your picture has been taken.
To take another timed photo, you must repeat the same steps again.
Hope that helps.
