Sounds Like it hasn't drained, or thinks there is still water in it. Take the drain hose out of the standpipe and place into a bowl. This will allow the machine to drain into the bowl. You'll need to then check the drain pump to find out why it hasn't drained....normally something like a hair pin stuck in the impellor stopping it turning
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
SOURCE: Miele w1918 check water light flashes and the
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter In this case the inlet filter and inlet valve is a suspect. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash. Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin. Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump. Please check the link below: http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help Thank you for using fixya.
SOURCE: the check drain and check
I have a Miele W502.
Both lights flashing usually is caused by a water leak into the case of
the machine which trips the float switch in the base. You can reset this
by tipping the machine forwards at 45 degrees and allowing the water to
drain out on to the floor. It will reset everything but if you still
have a leak it will trip ou again due to the float switch.
I had the same problem with the 2 red lights flashing, which was fixed by emptying the float tray as above.
On
further investigation I found that the door seal had rubbed on itself
at the 6 o'clock position and had worn a small hole which was causing
the water leak.
To replace or repair the Door Seal you will need to remove the front panel.
1. Turn power off and unplug machine after opening door.
2.
Remove the front panel lower kick plate by inserting a thin ruler
between the kick plate and front panel about 4 inches from each end and
lever down until it releases.
3. Remove the 2 screws at the door lock switch on the front panel.
4. With the kick plate removed you will see 2 screws at each lower edge of the front panel, remove these 4 screws.
5.
Remove the spring loaded band from around the edge of the door seal
facing you and after that release the seal from the front panel and push
in.
6. Remove the hex bolt from the 6 o'clock position just below the door seal on the front panel.
7. You should now be able to lower the front panel out of the locating pins and remove it.
8.
With front panel removed you will be able to remove the tensioning band
which holds the door seal in place around the drum by undoing the screw
at the right hand side of the band at the 3 o'clock position. It is
accessible from above with a long bladed screwdriver. Take note of how
far it is tensioned on the thread of the screw and try not to undo it
all the way or you may lose the nut on the band.
9. Once you have removed the band, slip the seal off the drum and slide the water outlet to the seal from the dispenser.
10.
When you replace the seal do not do the tensioning band up too tightly
or you will hear it squeak when you spin the drum in either direction.
11.Reassembly
is the reverse of removal, taking care to put the door manual release
strap through the inner slot in the front panel.
I repaired my
door seal with Silicone Sealant and loose weave fabric tape after
rubbing it clean with alcohol as i didn't want to pay $100 for a new
seal from Miele.
the pump is not working or it would be emptying the water out
check for something in the impeller stopping it from turning
(bra wire , coins , bobby pins etc)
have an technician check the power to the pump and the program board for correct operation
