DWM40F1Y1 40 inch TV
TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for parts. Sounds like the LED driver isn't working.
SOURCE: tv has sound but no picture
I had similar problem with my Polaroid 42 inch. The screen would be fine for 10 minutes or so then go black. I found a work around that solved my problem and maybe you can to. What I did was remove the back panel of the TV. Make sure it is unplugged first. You should be able to see the electical board. Somewhere on the board may be a switch that says "Burn" or something with "Burn" in it. I set the switch to the "Burn" setting and the TV has worked fine ever since. Good Luck.
SOURCE: Westinghouse VR3215 has sound but faint picture only seen using a flashlight.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
