Question about Yamaha Music
Yamaha electone hs6 pedals not working and hanging after some few seconds what might be the problem
    Sergeant:
  • 272 Answers
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: I have a yamaha electone hs4, The foot pedals do not work.
JM: Your problem is this: There are rubber washerson the bolt that holds the pedal on. They are shot. Most likely Yamaha doesnot have the parts.Go to the plumbing dept of a hardware store and get some faucet washers and replace them. YYou can tell if the washers are shot by tiping over the organ and looking at the pivot bolt. Most likely that is yoiur problem. I am an organ tech. and have replaced many of these. DM
Posted on Mar 16, 2009
guitarmanjoe
Joe Patch
  • 336 Answers
SOURCE: need an operator's manual for yamaha electone el-15
You can find it here
http://www2.yamaha.co.jp/manual/pdf/emi/english/ele/EL15E.PDF
Posted on Mar 12, 2013
Need a Repair manual for Yamaha Electone HC-4 home organ or source to purchase Motherboard for same
Request the repair manual directly from Yamaha. Fixya is unable to identify a source for the motherboard other than Yamaha.
Mar 19, 2018 | Yamaha Music
All the foot pedals on my 1972 Yamaha Electone D-7 from 'A flat' down sound like 'A flat'. What's happened?
That sounds like a problem with the contacts in the pedalboard or a short in the wiring harness. I'd suggest calling a tech in. You could cause a bigger problem if you aren't experienced.
Feb 05, 2016 | Yamaha Music
Organ repair
Yamaha electone organ have no sound el 25 need help thnks...
Sep 03, 2013 | Yamaha Music
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
Yamaha Electone HS4-two or three foot pedals do not play-happened after being moved. Could it be wiring and if so what do you look for? Have not tried to fix it.
Could be broken wires, however I think that dirty contacts are more likely, especially if the failing ones are kind of scattered. Many of these use conductive rubber contacts. For those use only 99% isoprophyl alacohol and Q Tips to clean them and where they contact. When moving dirt moves around and gets into the works !!!
Nov 30, 2010 | Yamaha Music
Yamaha electone organ no sound-
Check if you may have knocked off the speaker leads OR ones to an expression pedal.
Sep 16, 2009 | Boss Micro BR Digital Recorder
Hi, Yamaha Electone HS-4 NO SOUND
j have had the some problem on hs 7 . The relè not work probably you have a cold o breaked joint on power amplify integrate or it is broken.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Need an operator's manual for Yamaha Elecone organ model MFX-7420
Have you tried joining at the Electone Zone at www.electone.com? It looks like a fun site and its free to join. Maybe one of the members there can kindly help you.
May 24, 2009 | Music
Mar 13, 2009 | Yamaha Full-Size Keyboard
Music Logo
115 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
