SOURCE: Oven pilot light will not stay lit
The thermocouple is bad this is the probe that sits next to the pilot,the pilot flame heats the thermocouple and then it sends a micro voltage to the valve to keep it lit.Goto hobartcorp.com and find your model then the part number.
SOURCE: pilot light will not stay lit
Clean the pliot light tube with a Q-Tip and alcohol. Clean 2 inches deep. This will increase the pilot light flame and it will heat up the thermocoupler so it will stay lit.
SOURCE: Laars Lite 2 LG - pilot light will not stay lit.
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
SOURCE: my mr heater mh9b won't stay lit
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
SOURCE: Cant get the flame to stay lit after holding the red button
THIS IS FROM BRIKMANN WEBSITE SUPPORTMake sure the tip of the thermocouple is located over the edge of the burner so that it gets hot when the burner is in operation. Also, check all the wiring connections to make sure nothing has come loose. It is also important to use the turkey fryer with the pot that comes with the unit. The pot must sit on the spring loaded temperature switch in order to determine the temperature of the liquid in the pot.
